Would this setup work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taylor, Oct 19, 2013.
  1. Oct 19, 2013 at 7:23 PM
    Taylor
    Taylor [OP] Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
  2. Oct 20, 2013 at 6:43 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Yeah that setup should work well for example you.
  3. Oct 20, 2013 at 12:07 PM
    Dilly04Taco
    Dilly04Taco Well-Known Member
    Dylan
    Blue Ridge sc
    04 PreRunner ext cab
    Leveling kit Rims tires
  4. Oct 20, 2013 at 12:09 PM
    Dilly04Taco
    Dylan
    Blue Ridge sc
    ive Actually order the same set up besides the add a leaf instead of new leaf springs!
  5. Oct 20, 2013 at 1:35 PM
    Taylor
    Taylor
  6. Oct 20, 2013 at 8:04 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
  7. Oct 20, 2013 at 8:58 PM
    Taylor
    Taylor
    Hmm.... I don't know if I want to mix and match my shocks. Anyone else have some feedback on this setup here?
    Also, Around how much lift should I start looking at a diff drop?
  8. Oct 20, 2013 at 9:12 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I have the Dakar rears and love them. But I did a ubolt flip and rear shock relocation with 10" 5125's
  9. Oct 20, 2013 at 9:18 PM
    4banger4x4
    Eric
    Whorelando, Fl
    It's the setup I'm running and I love it. But it's not a big deal mixing and matching. They should all be valved for the tacomas.
    And diff drops are a waste of coin. They might change your cv angel but a degree or two but it changes your drive shaft angel because the spacers only drop the front of the diff, therefore it makes the pinion stick higher up in the rear.
    But if you have manual hubs like me you don't have to worry about your cvs
  10. Oct 20, 2013 at 9:58 PM
    SeattleCoug
    SeattleCoug Washington State University
    Mark
    Japanistan
    2015 TRD Off-Road
    I was about to say... I know it says those leafs give 2 1/4" of lift but if it gives more (expo leafs said 3" lift, I got 3.5-4)-- what I'm getting at is if it gives you more lift you may need longer shocks (Bilstein 5125s). I'd give Toytec a call and double check with them, and give DSM a call to double check as well
  11. Oct 20, 2013 at 10:06 PM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    I got about 2.5" and that's with a shell.
  12. Oct 21, 2013 at 3:23 AM
    4banger4x4
    Eric
    Whorelando, Fl
    It may seem like you got more than 3", but that's because your old spring were sagging and your new ones weren't broken in yet. And expo leafs give 3" of lift over stock when they have continuos weight on them
  13. Oct 21, 2013 at 3:36 AM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
  14. Oct 21, 2013 at 4:25 AM
    Taylor
    Taylor
    I'm looking for new leaves entirely. No AAL's here.
  15. Oct 21, 2013 at 5:04 AM
    monstertaco12
    Louisiana
    Well then Dakar or All Pro is the way to go. I got the Dakars and never looked back...
  16. Oct 21, 2013 at 6:16 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    That would make since to ask at this point. I know from experience that the regular All-Pro's do NOT hold any weight. My brother, who I lived and worked with when he got the AP's, had the regular ones and they would struggle with a bed of carpenters tools, however they would flex like no tomorrow. I had the Expo's on my truck for a minute before we went to Moab last year and I thought they were way too much leaf for my truck. He installed them on his truck with two of the leaves removed and he thought they worked well with his OME 882 and nitros in the front. He also had a 1" extended shackle in the rear. I changed to Dakars and the DX6L extra leaf for the trip to moab and then removed it once I took off the cap and sold it. Now it rides smooth and does well with the 10" 5125 shocks, but could have been the 9" ones.
    That was more like 5 cents.
    Brandon
  17. Oct 21, 2013 at 7:17 AM
    Taylor
    Taylor
    My intended use is to continue using my truck as a truck. I plan on eventually hauling a motorcycle in the future and maybe towing cars for my buddies in the Car club I'm in to and from the track. I also plan on wheeling. Nothing INSANE, but I want to go out and ride some trails from time to time.
    I really want leaves to lift and restore at least stock cargo rating. At this point, I'm sagging terribly with a few people in the bed.
  18. Oct 21, 2013 at 8:51 AM
    4banger4x4
    Eric
    Whorelando, Fl
    Consider the expos then, or call alcan, they custom tailor leafs to your needs.
  19. Oct 21, 2013 at 9:09 AM
    Lumpskie
    New Hampshire
    If you don't carry weight in your bed all the time, a standard spring pack will be fine. If you do have weight all the time, then you'll need a heavier pack. My Alcan 8 leaf pack doesn't sag much, even with 1000lbs in the bed. On the other hand, I need at least 150 lbs in the bed to get the suspension to flex.
    FWIW, BoxRocket has the OME rear setup and seems to like it. My setup was $550 and the OME setup you were looking at was over $150 cheaper. If it works, why get something more expensive?
  20. Oct 21, 2013 at 10:57 AM
    Taylor
    Taylor
    Yeah, I've never heard anything bad about the OME springs. I mean, I ALWAYS have my toolbox on the back which is loaded down, but I wouldn't assume it's more than 200-250 pounds.
