Would this work??? What do you guy think!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FXHO, Apr 28, 2013.
  1. Apr 28, 2013 at 3:37 PM
    FXHO
    FXHO [OP] Well-Known Member
    Luis
    Miami,FL
    2013 Toyota Tacoma DCSB TRD Sport
    Sup Guys
    i recently pulled the trigger and purchased a 2013 toyota tacoma trd sport 2x4. i have been dying to lift my truck and came to a decision on what i want to do but dont know if its going to work. need everyone's advice and help.
    so here it is:
    • 4" Maxtrac spindle lift w/ extended brake lines
    • 305/50/20 Xd Missfit Rims
    • Nitto Terra Grappler M/T Tires
    so my question is,
    • WOULD THIS WORK?
    • do i need to do any trimming?
    • can i get away without it rubbing if i add spidertrax wheel spacers?
    • would should i do in the rear? what would be the best option to keep my factory ride quality
    thanks
  2. Apr 28, 2013 at 4:23 PM
    BradyT88
    BradyT88 Well-Known Member
    Well that tire is only about a 32" so rubbing won't be too bad. You may still get the cab mount and maybe the frame with that wide of a tire though. If you are rubbing the frame, spacers should fix that, but will likely get you into the cab mount or fenders worse. If you are rubbing on the cab mount or fenders you will just have to trim.
    Overall since you will have 4" of lift I don't think the rubbing will be very bad if there is any, so I would go for it so long as you don't might trimming a little plastic if necessary and it probably will be only a little if you have to trim.
  3. Apr 28, 2013 at 5:38 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    What said
  4. Apr 29, 2013 at 5:30 AM
    FXHO
    Luis
    Miami,FL
    What would I need or what would you guys recommend I do to lift the rear
  5. Apr 29, 2013 at 5:32 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Add-A-Leaf. Do not use blocks
