Would this work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueTaco07, Jan 3, 2012.
  1. Jan 3, 2012 at 6:08 PM
    BlueTaco07
    BlueTaco07 [OP] Super Mod!
    Cody
    Panama city, Florida
    Looking
    I have a blisten 5100 setup on all four sides, 2" rear AAL and eibach front springs. The front has the 1/4 top plate spacers and driver side lean. But can I put a leveling kit on top of the plates to give alittle extra front lift?
  2. Jan 3, 2012 at 10:06 PM
    Nick701
    Nick701 Well-Known Member
    17 TRD OR DC 4X4
    Does the small 1/4 in spacer for the lean fit under the tophat of the strut assembly or above like the leveling kit does?
    I think if under, like sandwiched in with the spring, than no problem at all. If its on top, probably no problem but then it would be two extra pieces on top of the struts and I don't know. Prob no problem as long as you have proper threads to torque it down.
    Good luck
  3. Jan 3, 2012 at 10:32 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Instead of the spacers can't you just adjust the 5100s?
