Would y’all trust this battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Mar 3, 2021.
  1. Mar 3, 2021 at 11:06 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    north. In koura. 40 minutes north of Beirut.
    uurx likes this.
  2. Mar 3, 2021 at 11:09 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    cwdog likes this.
  3. Mar 3, 2021 at 11:12 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yeah their german.
  4. Mar 3, 2021 at 11:15 AM
    jardoo
    Beirut, Lebanon
    I guess I have to learn how to change the charging system. Thanks
  5. Mar 3, 2021 at 12:47 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    OVTune has the capability to adjust the alternator regulation settings to better support AGM batteries through their VFTuner software. There are at least two threads here with tons of info about the software and tuning of the 3rd gen tacoma ECU.
    Anton338 likes this.
  6. Mar 3, 2021 at 12:56 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Wtf varta ?? “Fart battery “
  7. Mar 3, 2021 at 1:00 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    German, should be good.
  8. Mar 3, 2021 at 5:05 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Just hit it with a float charger once a month or so to top it off, no biggie.
  9. Mar 4, 2021 at 11:48 AM
    jardoo
    Beirut, Lebanon
    Hey guys, so I got the battery. Do I just remove the standard battery and throw the agm one in? Thanks
  10. Mar 4, 2021 at 12:43 PM
    Lt. Dangle
    Ohio
    Yep.
    shakerhood likes this.
  11. Mar 5, 2021 at 8:19 AM
    trajiiic
    trajiiic Well-Known Member
    I thought you were joking, lol.
    uurx likes this.
  12. Mar 5, 2021 at 8:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's about an inch lower in height than a 24F. The factory J-bolts may bottom out. Easiest fix is a piece of wood or plastic sandwiched between the crossbar and the battery.
    Electrically it's plug and play. Hook up the positive first, then the negative. The only noticeable item that loses memory is the climate control settings.
  13. Mar 5, 2021 at 8:46 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    and make sure you connect Red to Pos and Black to Neg.
    I just felt like that was the next question or at least the next issue... The F in 24F means the terminals are reversed
