Would you buy a Tacoma with a replaced motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by double dee, Nov 15, 2012.
  1. Nov 15, 2012 at 8:17 PM
    double dee
    double dee [OP] Well-Known Member
    West Phoenix
    2016 Tacoma 4x4
    I am in the process of buying a used Tacoma. It is a 2010 DCSB 4x4. I just did a CARFAX on it and it says at 9,700 miles the motor was replaced. The truck now has 35,000 miles on it. Haven't talked to the owner yet about why. I was planing on calling the dealership it was replaced at to see if they can give me any info. Would you run away or still be interested? My thought is it was replaced while it was still under warranty 25,000 miles ago so I would assume any problems for it would have come up by now
  2. Nov 15, 2012 at 8:38 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    well i found this from the vin.
    SHORT BLOCK R&R ~|~C.S HEARS A CLICKING NOISE ON DRIVERS SIDE---AT IDLE--- ~|~FOUND SEVERE METAL IN PAN--4--ROD BEARING SPUN-CRANKSHAFT SCORED- ~|~9805 CHECK NOISE IN ENGINE AREA UPON INSP FOUND INTERNAL ENGINE NOISE,CONTACTED TECH SUPPORT,CASE#TA101520055,SUGG REMOVE AND TEAR DOWN AND INSPECT,REMOVED AND TORE DOWN,FOUND SEVERE METAL IN PAN,#4 CONNECTING ROD BEARING SPUN,CRANKSHAFT SCORED,REFERED TO
  3. Nov 15, 2012 at 8:43 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Dont worry about it. If you want take it some where for them to check it out before you buy.
  4. Nov 15, 2012 at 8:44 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    2 things I would NEVER do: 1) Buy a semi-new vehicle that has had the engine replaced and 2) Shove a dead hooker into a twin size mattress....it just isn't big enough!
  5. Nov 15, 2012 at 8:47 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    well thats two different answers.....
  6. Nov 15, 2012 at 8:47 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Midget ones fit just fine:cool:
    I bet you would be just fine. But it might be something to be able to talk down the price?
  7. Nov 15, 2012 at 8:49 PM
    TeamLombardo
    Tony
    El Paso
    The second one was just for S.A.
  8. Nov 15, 2012 at 8:53 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    It was well documented and done by the dealer I wouldn't hesitate.
  9. Nov 15, 2012 at 9:00 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    That what i'm thinking but has kinda given me an uneasy feeling.
  10. Nov 15, 2012 at 9:00 PM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    this
  11. Nov 15, 2012 at 9:05 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    would it be possible they replaced it with a used motor?
  12. Nov 15, 2012 at 9:07 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Not for warranty work.
  13. Nov 15, 2012 at 9:08 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    that makes me feel a little better
  14. Nov 15, 2012 at 9:10 PM
    Large
    Large Red
    Still has a 60k mile power train.
  15. Nov 15, 2012 at 9:10 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    These trucks are simple enough that having a motor replaced on one isnt a big deal.
  16. Nov 15, 2012 at 9:21 PM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    thanks guys:bowdown:
  17. Nov 15, 2012 at 9:32 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Short block is engine cylinder block with crankshaft, rods, pistons installed. That means a dealership mechanic transfered everything else over from the original engine. That includes the cylinder heads. I just wonder about how much metal made it up to the heads, if any.
    A tech doing flat rate warranty work may or may not stop and gain approval for additional work to correct damage to those heads, if he discovers it later, while the truck is apart and in his work bay.
    If it was an entire assembled engine, I would not have any major misgivings about it, especially 25K miles later. But since it was short block only I would worry about top end problems that might not show up till 100K or more.
    Depends on what you want. If the plan is to buy a 100K warranty and sell before it's out of warranty, go for it. If you are going to try and drive it over the 100K mark, I would pass.
  18. Nov 16, 2012 at 8:42 AM
    double dee
    West Phoenix
    2016 Tacoma 4x4
    anyone else have more input?
  19. Nov 16, 2012 at 8:57 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Phoenix / Payson, AZ
    98 Tacoma Limited
    Deck Plate, '17 rims, Tundra Brake Upgrade, All-Pro Expo Leaf Packs, 01-04 Center Console, Ultragauge, LED interior lights, HO alternator...
    ^ This
  20. Nov 16, 2012 at 9:06 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I wouldn't be worried if the truck was at 150, but it's only at 35.
    Why is the guy getting rid of it at 35 when he just got the engine replaced 20k ago?
    I'd be very suspicious that he's selling because they didn't fix whatever is wrong.
