Would you buy again ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fallsguy, Feb 19, 2017.
  1. Feb 20, 2017 at 7:12 AM
    #101
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    And Your point is. Maybe it did blow up sometimes shit happens. Do you or I know why it blew up. Maybe he was doing something he should of not done.
    Spare Parts, bobrown14 and Mush Mouse like this.
  2. Feb 20, 2017 at 7:13 AM
    #102
    2016LimitedTaco
    2016LimitedTaco Well-Known Member
    Derek
    2016 Tacoma Limited
    Rear heated seats, pop-n-lock tailgate, undercover flex tonneau and bed lights
    I get where you're coming from but no. Very slippery that day. However lets just say it was dry pavement, middle of summer and spinning on gravel at high speed and then grabbing asphalt. I still firmly believe that should not tear apart a rear end. Maybe if it was repeated over and over again or a high mileage vehicle.
    shakerhood likes this.
  3. Feb 20, 2017 at 7:13 AM
    #103
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  4. Feb 20, 2017 at 7:16 AM
    #104
    Mush Mouse
    mush
    2013 SR5
    yes!!!
    Broken Ring and Pinion:
    The teeth have been sheared off this ring and pinion set. This is evident in the dull grey areas. The shiny areas have been hammered by the broken gear pieces. This does not indicate that the ring and pinion gear set was defective, but rather that too much power was applied with too much resistance in the tires. This can be caused by too much power combined with oversized tires or tires that are stuck on an off road obstacle. Spinning tires that suddenly catch either off road or on the track can break differential parts as well. Click Here for a larger image
    bobrown14 likes this.
  5. Feb 20, 2017 at 7:16 AM
    #105
    2016LimitedTaco
    Derek
    2016 Tacoma Limited
    I was not doing anything but humor me for a second. Could you take a brand new truck and take out the ring and pinion without first damaging something else? I'm not being sarcastic or combative but seriously. No one was a bigger advocate for Toyota and especially Tacoma than me. This is really disappointing. I bought a Tacoma against all others because it's a Tacoma! Change the oil and drive it two or three hundred thousand kilometers.
    CusterFan and shakerhood like this.
  6. Feb 20, 2017 at 7:16 AM
    #106
    NM Lance
    NM Lance Well-Known Member
    I am almost tempted to go out and dump 37K into a truck I don't need just to see how "bad" these things really are.
    If it turns out to be a real POS, then I can tell everyone I am truly having a mid-life crisis.
    Mush Mouse and 2016LimitedTaco like this.
  7. Feb 20, 2017 at 7:19 AM
    #107
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    this is really concerning. My #1 question is could this have been prevented? Should I be checking/changing my diff fluid in my 4k mile Tacoma pronto?
  8. Feb 20, 2017 at 7:22 AM
    #108
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yes I would and +1 on that ^^^^ and BroHo puddles too!
  9. Feb 20, 2017 at 7:28 AM
    #109
    s4awd
    s4awd Active Member
    I actually looked into the RS. Had an Evo VIII, and to still hear reviews that the RS still hasn't matched the Evo X in handling and sharpness, threw me off.(of course everything else about the RS is better) Anyways had a '00 TRD 6MT. Came back 6 years after it was recalled and picked up a Pro 6MT. So yes. I'll prolly disappear for another 15 years and come back and reply again :)
    Rownan[QUOTED] likes this.
  10. Feb 20, 2017 at 7:29 AM
    #110
    Mush Mouse
    mush
    2013 SR5
    I would check the level, and not pull any hole shots on icy roads , good preventatives
  11. Feb 20, 2017 at 7:34 AM
    #111
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Spare Parts likes this.
  12. Feb 20, 2017 at 7:38 AM
    #112
    s4awd
    s4awd Active Member
    I was dead set on the auto and yeah, it's pretty bad. I thought it was just me when test driving. I was like, why does this truck feel weak? The motor mated to the manual is fine given you are tapping all of the power when you want it. If there was more power, I'd want better brakes. Rear discs Toyota! The 6MT makes it a great truck. (Of course you give up quite a bit, craw, smart key, etc) If you are open to driving a 6MT, you may want to test drive it.
  13. Feb 20, 2017 at 7:44 AM
    #113
    Mush Mouse
    mush
    2013 SR5
    Tundra?
  14. Feb 20, 2017 at 7:45 AM
    #114
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Disc brakes are not "better" than drum brakes, will not stop you sooner etc... reason for drum brakes is less wear due to mud sand etc ....and wheeling...
    Spare Parts, Mush Mouse and gpb like this.
  15. Feb 20, 2017 at 7:47 AM
    #115
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Is Toyota taking care of it for you? What did they say if so? Glad you're safe from when it occurred.
    OA
    EDIT: Didn't see you created a new thread - I'll stop this convo here even though this thread is off the rails.
  16. Feb 20, 2017 at 7:49 AM
    #116
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Each has its tradeoffs. Rear discs do have an advantage for towing as they can bleed off heat better. Rear drums won't effectively change braking though unless you're driving backwards. Weight transfer to the front axle takes most of the braking load off the rear axle and but for ABS you'd easily lock either.
    Blanket statements of wanting disc over drum on rear axles just shows that marketing works.
    bobrown14[QUOTED] likes this.
  17. Feb 20, 2017 at 7:50 AM
    #117
    Mush Mouse
    mush
    2013 SR5
    lets just say your not telling the full story, shall we. the rear diff wont just shread pinion teeth like that unless there was serious operating flaws by the driver spinning the tires at a high rate and then grabbing traction this shit doesn't just happen and I don't know why
  18. Feb 20, 2017 at 7:57 AM
    #118
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Shouldn't the question be WHY, not WHAT?
  19. Feb 20, 2017 at 7:58 AM
    #119
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Why do the 4R and Landcruiser come with rear discs then as they are marketed as OR vehicles?
  20. Feb 20, 2017 at 7:59 AM
    #120
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Why yes I believe so.. it's one of those brain things where your brain wants to see the correct thing so your eyes tell you what your brain wants to see?? o_O
    I was trying to be a funny.... instead of saying something negative in reply..
    Mush Mouse likes this.
