Would you LT a long bed DC?
Discussion in 'Long Travel Suspension' started by hockeypoor, Aug 29, 2010.
  1. Sep 5, 2010 at 12:06 PM
    #41
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    so you guys condone reusing you stock trd coils when getting a LT?
  2. Sep 5, 2010 at 12:53 PM
    #42
    hockeypoor
    hockeypoor [OP] Well-Known Member
    Central Coast of California
    Speedway Blue All stock Prerunner
    No you cant use the stock coilovers with LT. I am putting LT in the rear first and just doing spindles in the front for now.
    The rear is always the biggest limiter. So I figured I would do that first.
  3. Sep 5, 2010 at 12:58 PM
    #43
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    05 4 banger
    tint 35/20 colormatched (by me) grill.
    sounds like youve got a good plan man...cant wait to see it on the truck!:D
  4. Sep 5, 2010 at 1:36 PM
    #44
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    Wish I did that way first.
  5. Sep 9, 2010 at 6:38 AM
    #45
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    So for those of you guys that have your trucks done I have a quick question......I would love to lt my dc long bed but are you still able to tow or haul a load in the bed or does it become absolutly useless at that point? And in order to lt the rear is it tottally necessary to cut into the bed in order to get the shocks set up?
  6. Sep 9, 2010 at 6:55 AM
    #46
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    it depends on how much cage work you get done in the rear... if your going w/ a typical SUA and bedcage set up you can keep some of your bed or have no more bed at all. i'm going to get a cage built similar to this so i can still use some of my bed
    bajamoon has alot more cage work in the back of his truck and no more bed
    there are other options out there like a cantilever set up that doesn't cut into the bed at all (it just expensive and can be a bitch to tune the shocks) or check out the defined eng. SUA kit...
    http://www.definedengineering.com/products.html
  7. Sep 9, 2010 at 7:42 AM
    #47
    bajamoon
    STEVE
    Whittier
    like said above it depends on how far you go. As for towing it depends on what you are towing, a travel trailer is not a good idea but a small trailer with a motorcycle should not be a problem, Do a small bed cage and you can still carry a load in the bed just not as much as stock.
  8. Sep 9, 2010 at 8:45 AM
    #48
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    What do you guys think about a cantilever set up with a SUA? That way the shocks and frame are under the bed and I can still use the full bed. would this even be an option? Or would the shocks be too much of a pain in the ass to set up?
  9. Sep 9, 2010 at 9:02 AM
    #49
    bajamoon
    STEVE
    Whittier
    you can do that, do know how hard it would be to get the shocks dialed in thou, it won't be easy.
  10. Sep 9, 2010 at 9:04 AM
    #50
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  11. Sep 9, 2010 at 9:05 AM
    #51
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    install isn't as straight forward as a reg SUA either
  12. Sep 9, 2010 at 9:05 AM
    #52
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  13. Sep 9, 2010 at 9:12 AM
    #53
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    whitecloud, check out evotaco's bedcage on his double cab long bed... hardley takes up any space at all
  14. Sep 9, 2010 at 12:16 PM
    #54
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Do the defined engineering SUA if you want to keep your whole bed and some shock hoops with a removable cross brace. I have met the owner of the defined engineering and he is a great guy and a perfectionist. Also if you don't have the money to build a cage or shock hoops you can use stock length shock on it until then but you won't get as much up travel. Also the springs he uses are a custom made deaver pack that only he can get and it still holds weight a lot better then my race leaf pack I'm running. We installed a kit a few weeks ago and It rode really nice I thought.
  15. Sep 9, 2010 at 4:39 PM
    #55
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    those are the only 2 pics i know of... IDK who built it but it looks really similar to DMZ work
    check out their website www.dmzfab.com
  16. Sep 9, 2010 at 4:41 PM
    #56
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    wow that is nice and clean
