Would you replace the front bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ricky B, Dec 29, 2017.
  1. Dec 29, 2017 at 11:59 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    I have a roar in my frontend of a 2007 Tacoma. It does quite down when I engage it in 4wd. I purchased the ECGS bushing and plan on installing it this weekend if weather permits along with a axle on the drivers front. I have already purchased two front bearing kits from bamaboy. With 194,000 miles on the truck and I have no idea if the bearing have ever been changed and I highly doubt it. Would you guys change the bearings while your in there? By swerving right and left the truck has no change so really don't have a clue if bearings or bad or not. There is no slack when I jack them up off the ground but with almost 200,000 you would think they are getting close. Thanks Rick
  2. Dec 29, 2017 at 12:07 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Why not - it's easy peeze and U R there.
  3. Dec 29, 2017 at 12:16 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my front wheel bearing didn't change much when swerving until after a few months and no change in 4wd
    it might be wheel bearings too or just the ECGS will fix it
