Would you take a road trip with a “chirpy” throw out bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xaircav, Aug 5, 2020.
  1. Aug 5, 2020 at 5:34 AM
    xaircav
    xaircav [OP] Well-Known Member
    Bill
    Wheat Ridge, CO
    '10 TRD Access Cab 6 speed manual
    TRD intake, skid plate, cat back exhaust and short throw shifter. Bilstein 5100 leveling front and 5100 shocks rear. 32” Falken WP AT4W tires on Gen 3 wheels.
    Subject is a ‘10 OR, six speed/4.0 with 120k miles. Trip is 1400 miles round trip mostly interstate. T.O. has been squealing for about six months. Noisy at idle in neutral, goes away when pedal is depressed. Your thoughts please.
  2. Aug 5, 2020 at 5:59 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Six months? Oh ya, go for it. Nothing's happened yet? From other posts here, guys just learn to live with it.
  3. Aug 5, 2020 at 10:41 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Bought my xrunner with 93k miles with squeaking throw out bearing. Never touched it and drove another 150k or so.
  4. Aug 5, 2020 at 10:45 AM
    eon_blue
    Azusa, CA
    Most people, myself included, just live with the chirping. A throwout bearing failure on a Tacoma is very rare, in fact in spite of all the complaints about it on here and how common it is I don't think I've heard of one actually failing. Its the noise that drives some people nuts
    US Marine likes this.
  5. Aug 5, 2020 at 10:49 AM
    su.b.rat
    su.b.rat broken truck
    mine is bad and it's new. i put it in a few months ago when replacing everything else, and it's a OE TOB, the right part, just a dud apparently.
    i can't get it back in the shop as soon as i wanted so I'm stuck with this noisy thing. the sound continually changes and also goes from super loud to silent and it's not just about warning up, haven't figured it out. but it will be replaced again hopefully within the month. the changing sounds does make me uneasy and i avoid engaging it as much as possible.
    my sound is not chirping but between grinding and bead in a bowl.
  6. Aug 5, 2020 at 10:50 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Should be fine.... I wouldn’t worry about it.
  7. Aug 5, 2020 at 10:53 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Hell yes I would. It’s annoying, but you should be fine
  8. Aug 5, 2020 at 11:41 AM
    Iceberg
    Iceberg Well-Known Member
    Josh
    Alabama
    2008 DCSB TRD OR
    Mine has been squeaking for 30,000 miles or so. I’ll replace when I do the clutch but have learned to live with it. May do the clutch master or urd fix when I do.
  9. Aug 5, 2020 at 11:42 AM
    eon_blue
    Azusa, CA
    From what I've heard the Clutch Master fix is the way to go, the URD one doesn't always do it.
  10. Aug 5, 2020 at 12:39 PM
    mea4dxl
    mea4dxl Well-Known Member
    NY/NJ
    2012 Access cab 2wd
    i prob wouldnt
  11. Aug 5, 2020 at 12:46 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It will potentially, over time, slowly wear down the pressure plate fingers and the bearing itself, thus making the chirping worse. However, it will not cause catastrophic failure and will continue to function (aside from the unpleasant noise) for the foreseeable future with likely no additional cost to repair.
    You're fine.
    Jeff
