Would you tow this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sechsgang, Jun 25, 2011.
  1. Jun 25, 2011 at 6:59 PM
    sechsgang
    sechsgang [OP] Well-Known Member
    06 DC TRD OR 4WD 6spd
    Would you tow this trailer one time only, about 120 miles one way, without a weight distributing hitch?
    We plan on buying that trailer, but I probably can't get the WDH before next (4th of July) weekend, and the campground is booked.
    Basic specs:
    - dry weight = 3,630 lbs
    - tongue weight = 460 lbs (approx.)
    - we would probably have about another 500lbs worth of "stuff" in the trailer, and some in the bed. So total trailer weight is probably just over 4,100 lbs or so.
    Towing would be all flat terrain, down I-5. Would you do it? On the RV forum people said "no, no way". :( But hey, the people over there seem over-cautious. Has anybody here towed something similar without a WDH?
  2. Jun 25, 2011 at 7:06 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Truck have the towing package? and 4.0?
  3. Jun 25, 2011 at 7:09 PM
    sechsgang
    Yes, 4.0 with factory towing package and electric brake controller.
  4. Jun 25, 2011 at 7:12 PM
    BlueTaco07
    Cody
    Looking
    Why wouldnt you be able to our trucks are rated at 6500lbs?
  5. Jun 25, 2011 at 7:22 PM
    sechsgang
    Just concerned about sway. Short wheel base on the DC short bed. Looking for some real life experiences here with something similar.
    The WDH basically distributes the trailer tongue weight to all axles, taking some away from the trucks rear axle and putting that to the truck's front axle & the trailer axles. Much better handling with that.
    But what most concerns me is sway.
  6. Jun 25, 2011 at 7:23 PM
    BlueTaco07
    Cody
    Looking
    Mines done outstanding on towing. Just dont tow in over drive haha
  7. Jun 25, 2011 at 7:24 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    If you have the tow hitch stage 3 or whatever and the 4.0
    I'd do it
    <--- I said I WOULD do it, Im not telling you to do it or not thats up to you.
  8. Jun 25, 2011 at 7:25 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Well within tolerance... Do it.
  9. Jun 25, 2011 at 7:26 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I would do it, personally, just know the risk involved and be mindful of course.
  10. Jun 25, 2011 at 7:29 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My brother has a 3,500lb dump trailer that I tow when doing home projects. I have had it loaded with 3 yards of bark and driven through town (not sure of how much weight that is). I can definitely tell it is back there, but I really like how my truck pulls it. I think 4,100 lbs is very doable. Good luck.
  11. Jun 25, 2011 at 7:30 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    max tongue load is 650 lbs and towing capacity is 6500
    you WILL be fine
  12. Jun 25, 2011 at 7:31 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I pull a trailer very close to that size. I bought it about 100 miles away and pulled it back without a WDH, it did fine but definitely seemed to 'push' the Taco around a little. I've always used the WDH every time since.
    My call: go for it, slow down a bit, get your rear tire PSI close to the max recommended. Do your best to pack with heavy suff lowest; if you can get water at camp, drive there dry, etc.
    Good luck!
  13. Jun 25, 2011 at 7:58 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    I have towed boats that weigh more than that at 70mph on the freeway with no problem. If you dont have the rear spring TSB or some differant springs you will end up being a bit nose high in the ground but you should be fine. The truck will bog a bit going up hills but you will be fine.
  14. Jun 25, 2011 at 8:01 PM
    sechsgang
    Yeah, I think it will most likely work ...
    The difference between travel trailers and utility trailers or boats is that you are pretty much trying to tow a wall. The wind resistance is as bad as the weight. That especially applies also to side winds, which will give the trailer the urge to sway.
    I'll report back next week. :)
    EDIT: And thanks for all the replies.
  15. Jun 25, 2011 at 8:42 PM
    extremachn1
    Turd Furgison
    Tucson, AZ
    I tow a 14x8 enclosed trailer as well when I go to the dunes and race track with buddies. Much lighter but also like towing a giant wind sail, you will be fine. Just watch for windy areas.
  16. Jun 26, 2011 at 10:16 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
  17. Jun 26, 2011 at 12:11 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Yes I would-
    Last Oct I pulled a 5x8 Uhaul trailer (loaded weight justover 5k) from WA state through the passed in MT. Down to CO and across throughMO and finally to NJ. I had literally no issues and was even able to maintainthe speed limit going up all the passes through Idaho and Montana. It onlybecame a little squirrely going down a couple of the larger passes. Slowed downwhen needed and the trailer calmed down. I was actually very surprised by howwell it towed!
    (I have 4.0 w/tow package)
  18. Jun 26, 2011 at 12:16 PM
    utahskierdave
    utahskierdave Well-Known Member
    salt lake
    08 tacoma dbl cab
    You should have no problems towing that rig....if your brake controller (get a prodigy) allows you to activate the trailer brakes only via a switch on the controller just tap that whenever you see the trailer start to sway and that should bring it back in line. My wife and I are thinking of buying a trailer just like the one you will be towing...let me know how you like it...
  19. Jun 26, 2011 at 12:16 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    As long as you have teh 4.0 and two... sure. If thats thing is a single axle trailer, would I tow it, HELL NO. I hate single axles....
    Dual axle in a heartbeat. You will hardly feel that trailer behind you.
  20. Jun 26, 2011 at 2:14 PM
    sechsgang
    Will do, we just bought the trailer. :)
    Thanks everybody for your replies, very encouraging .... ! :)
