Would you trust this coil compressor?
Discussion in 'Suspension' started by mjl, Jun 16, 2010.
  1. Jun 20, 2010 at 7:42 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    Those are difficult to work with if you have the progressive TRD Springs........I would not recommend it after my experience with them. They got the job done, but those brackets are so thick that the spring starts to bind on them as you're compressing them.
  2. Jun 20, 2010 at 7:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i couldnt get the clamshell one from harbor freight to work at all dude....so now mine is just sitting on the shelf collecting dust.
  3. Jun 20, 2010 at 7:49 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    No, I wouldn't trust the compressor in OP. To many angles in those cradles and they look a bit thin. I think I've broken wrenches that looked beefier than those.
    The ones I see most frequently in this thread appear to be these. I just used them this weekend on my Sport springs... had to compress/decompress 4 times (oops) and never felt like they were going to slip. Very solid. I did it by hand with a regular socket wrench... not recommended entertainment but do-able.
    Friend of mine had the and it worked well a couple of times but the last time he used it he couldn't fully release tension and wound up having to cut the cradles off one end.
  4. Jun 21, 2010 at 2:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No shit? Will it work with no spring? It may be defective..?? :confused:
  5. Jun 21, 2010 at 2:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....works fine on its on. usctacoma came here mod weekend....and i couldnt install his lift for him because the damn spring compressor wouldnt fit into the spring to collapse it. i tried for an hour with zero luck.
  6. Jun 21, 2010 at 2:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well shit....I wonder where the one I used came from. :confused: The one I used worked fine.
  7. Jun 21, 2010 at 2:30 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've used both the harbor freight compressor and the more common type (two threaded clamps per spring). I felt like the harbor freight clamshell type was safer, but I found it a little more difficult because it would bind up when trying to get it on or off the spring. It was easier to compress the springs because it only has one bolt to turn, but I spent more time getting it on and off the spring than I did changing out the strut.
  8. Jun 23, 2010 at 10:10 PM
    10zin
    10zin Member
    hawaii
    03 PreRunner SR5
    3'' Toytech lift
    make sure the compressors sit opposite of eachother. Position the spring perpendicular to your body so if the compressors slip off the spring wont shoot at you
  9. Jun 23, 2010 at 10:28 PM
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
    Some shops also rent out tools. My local automotive shop like Kragen does.
  10. Jun 24, 2010 at 2:40 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Hmmm....with all the trouble that some are having with compressing springs, I might have a shop do mine. What is a fair price to pay for having this done?
  11. Jun 24, 2010 at 2:57 AM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    i don't think i could trust myself doing this:p
