Would you trust this to hang a fan from?
Discussion in 'Garage / Workshop' started by AmorPatriae, Feb 18, 2017.
Would you hang a small fan from this box?
  1. Yes
    3.1%
  2. No
    96.9%
  1. Feb 18, 2017 at 3:03 PM
    AmorPatriae
    AmorPatriae [OP] Well-Known Member
    12 DCSB SR5 4x4
    TRD Sport Hood, Truxedo Lo Pro Tonneau cover, OEM Bed Extender, SOS Front Bumper, SOS Rear Bumper, Pro Comp 84 Series Vapor, Goodyear Wrangler Duratrac
    So I'm getting a new house built and the kids rooms don't come with wiring for a fan but I can just use a remote switch. There are screws holding it in place. My question being. This is the light box in the room, would you hang a small fan from it as it is?
  2. Feb 18, 2017 at 3:10 PM
    pruchai
    pruchai KAMA3
    Igor
    San Diego, CA
    '14 TRD TX Baja
    Not enough...
    No. But these things are easy to replace after the house is built. I did in mine.
    wilcam47 likes this.
  3. Feb 18, 2017 at 3:10 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    There should be a 2x4 between the roof trusses and a pancake box for the electric. That bar is not strong enough for a ceiling fan.
  4. Feb 18, 2017 at 3:11 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    No. But since it's exposed this is a 10 minute job to run a proper ceiling fan bar with electrical box. Any box store will have one. If it was me I would lay a 2x4 on top of the 2 joist and screw a metal electrical box to it.
    RedRed, ChemDawg, ejl923 and 4 others like this.
  5. Feb 18, 2017 at 3:12 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Just screw a 2x4 across the span.
    98tacoma27 likes this.
  6. Feb 18, 2017 at 3:13 PM
    AmorPatriae
    12 DCSB SR5 4x4
    Sadly my builder wouldn't let me add my own bar so I will just have to do it once I take ownership.
  7. Feb 18, 2017 at 3:14 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    THIS
  8. Feb 18, 2017 at 3:17 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Hell No! Replace that
  9. Feb 18, 2017 at 3:22 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    After inspection, before drywall, you can replace that crap with something much sturdier, like a 2x4 with the box screwed to it.
    Pickeledpigsfeet and Tom Servo like this.
  10. Feb 18, 2017 at 3:25 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
  11. Feb 18, 2017 at 3:26 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Just a thought: I never found ceiling fans to be of any use, whereas a cheap Home Depot window fan has been able to lower temps in my bedroom by 1-2 deg.
  12. Feb 19, 2017 at 5:24 AM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    It will be simple to remedy when the builder is done. What code prevents him from doing it for you. You are his customer, he should be doing everything he can to make you happy, especially if it comes with a warranty.
    ChemDawg and Cazzwell like this.
  13. Feb 19, 2017 at 5:26 AM
    sjwhitaker
    Jake
    Berea, KY
    Same here, we have a 16" pedestal style fan in our bedroom and we can't sleep without it. It makes a huge difference in the temperature of our bedroom whereas the ceiling fan doesn't do Jack. Before anyone asks, yes the ceiling fan is on the proper setting.
    cruxofthebisquit and Cazzwell like this.
  14. Feb 19, 2017 at 6:22 AM
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    Agreed, but see if the box is rated for a fan.
    It looks pretty similar to this except the box is a different color.
    www.homedepot.com/p/100114498
    If it isnt and you have access to the attic space it would be easy to change out later or see if he'll move it over next to the truss. Then you could anchor to the truss and use the box to run the wiring into.
  15. Feb 19, 2017 at 6:31 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I would hang the box myself before the Sheetrock goes up. But in one of my rooms that did not have a fan box, I used a retrofit fan bracket from Home Depot that you don't even need to go into the attic to install. It was easy and the fan is still hanging.
  16. Feb 20, 2017 at 7:58 AM
    horstuff
    horstuff Re-member
    PNW
    2015 Base 2.7 Access Cab 4x4 5 sp
    ? Wtf? Then have him get his electrician to do it. Makes no sense that you can't get this handled before the lid goes on.
  17. Feb 20, 2017 at 8:01 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    IMHO
    ceiling fans are best to blow heat back down... to keep it warmer
    but for cooler ..yeah exhaust that hot air out the window and draw cool air in
    from some other window
    Jarod888 and cruxofthebisquit like this.
  18. Feb 20, 2017 at 8:06 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    There are special fan/fixture rated boxes required for code (at least in my area). A regular pancake or metal box will not pass the code.
    cruxofthebisquit likes this.
  19. Feb 20, 2017 at 8:13 AM
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    Smoke that mother f*cker!! F*cking rat. Half ass little shit like that and can't even do a simple task like that? What else has he half assed for you.
  20. Feb 20, 2017 at 8:14 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    I would frame a 4" box in with 2"x4" between the trusses
