wow. fan belt shredded wrapped around fan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VikingTrad3r, Aug 17, 2016.
  1. Aug 17, 2016 at 9:15 AM
    VikingTrad3r
    VikingTrad3r [OP] Well-Known Member
    "contractor model" white with black fenders
    so i am in the middle of a 12 hour road trip and i decided to lift the hood. didnt hear anything but this is what i found. not sure how long its been there.
    anybody had this happen?
    you can see the shreds around the fan, and the serpentine belt has a strip missing.
    i will see if i can find a store to sell me the serp belt. i tugged at the shreds by hand quickly they feel very solidly wedged in there.
  2. Aug 17, 2016 at 9:34 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    get a knife, cut the strands out of there.
    Get a replacement belt and put it on, keep your old one as a spare.
    Aw9d likes this.
  3. Aug 17, 2016 at 9:36 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Yes, mine did that same thing a few months ago out of the blue. Luckily I was on my way to a dealer to get my frame inspection done, so I had them replace the belt. I was told it was just old, and chose then to start to come apart. It went at about 120K.
  4. Aug 17, 2016 at 10:28 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I changed mine out years ago and didn't get it securely on all the pulleys and it shredded like this. Consequently the second time I changed the belt, years later, I found pieces of torn up belt wedged behind two of the pulleys. Cleaned it up and running great since.
    tinker_troy likes this.
  5. Aug 17, 2016 at 10:53 AM
    VikingTrad3r
    went to an oil change place with a new belt i got a a partsource here. took a while but we got it unwound using wire cutters. the new belt proceeded to shred the INSIDE edge immediately. we stopped the engine and nipped ghe shredded piece off
    the original shredded belt though was damaged on the outside edge.
    so we were dumbfounded.
    i am back on the road with another shredded serpentine belt. the previous shredded belt is in the back seat.
    im guessing he either installed it uneven and that caused the insta-shred or ...i have a damaged pully. but damage on both sides of pulley?
  6. Aug 17, 2016 at 10:58 AM
    tan-ishman
    tan-ishman Well-Known Member
    San Diego,CA
    2005 DCSB
    a bunch of new/used parts....and some skids.
    had this happen, twice.
    put the replacement on and it turned out the alternator seized and it was like shred zilla under there.
    I'd say make sure everything still spins that should spin before you put another nice belt on there.
    pliers, gloves, pull that skid plate off and go to town!
    *if something is bound that shouldn't be, you might find a bunch of burned/melted belt on it from where the belt just rubbed till it snapped*
    timbobzimbob likes this.
  7. Aug 17, 2016 at 11:12 AM
    VikingTrad3r
    thnx tan. was the t totally seized or just added resistance? i have no signs of any systems failures (steering/ac/waterpump/alt) so im thinking its not a full on seizure.
    ive pulled over twice to check if any further shredding has happened and none.
  8. Aug 17, 2016 at 11:14 AM
    tan-ishman
    San Diego,CA
    2005 DCSB
    alternator was totally locked up. didn't move a bit.
    maybe just an old belt. I'd say grab a new one before the rest of it goes.
    breaker bar and a second set of eyes to line it up and you can get that new one in. No probbbb!
    look REAL hard before you start the truck up. just to make sure you put it on right. =]
  9. May 4, 2017 at 9:40 AM
    DayStars
    DayStars Well-Known Member
    benn
    Edmonton
    07 Tacoma TDR 6spd DCSB
  10. May 4, 2017 at 9:51 AM
    VikingTrad3r
    thank you for the heads up on this. When I installed the second one it Insta shredded. But only a tiny bit of it. I peeled it out and the truck has been running since then with the same belt that has a few pieces missing. So far it's fine.
    ironically, I am driving the exact same 12 hour trip that I did the last time this happened I made this post. And here you come now again reminding me that I should be careful! Thank you and I'm glad you got yours sort it out. I will in fact inspect my oil cooler hose to see if they took any hits and is possibly compromised. No leaks as of now.
  11. Jun 13, 2017 at 1:16 PM
    GUN SLINGER
    GUN SLINGER Well-Known Member
    Colorado
    2018 TRD OFF ROAD DCSB QUICKSAND
  12. Jun 13, 2017 at 1:29 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    171k on my OEM belt, maybe this will make me change it
  13. Jun 13, 2017 at 2:49 PM
    VikingTrad3r
    I just installed the gates pulley set on the weekend, sans the tensioner pulley, and wow my truck drives and sounds like a new truck!!!
    tan-ishman likes this.
  14. Jun 13, 2017 at 9:52 PM
    tan-ishman
    San Diego,CA
    2005 DCSB
