WOW....Seafoam works
Discussion in 'Performance and Tuning' started by toyo freak, Mar 10, 2011.
  1. Mar 10, 2011 at 12:28 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Well I bought two cans at walmart for 8.50 a piece , and was hoping to clean up my old outboard mariner. After about five minutes the difference was unbelievable. So I figured why not seafoam my taco. My truck is a 2010 with 20K miles, and I could not believe the junk that came out of the tailpipe. Now the truck idles and runs like it did the day I got it. What a difference. Anyone have similar results on a newer taco?
  2. Mar 10, 2011 at 12:32 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I'm still scared to do it...
  3. Mar 10, 2011 at 12:32 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    How'd you run in it in your outboard?
  4. Mar 10, 2011 at 12:33 PM
    jrdbrn
    Jared
    Louisiana
    '21 TRD Off Road
    +1
    My luck, I'd hydrolock it. Not wanting to even chance it.
  5. Mar 10, 2011 at 12:34 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    It does work very well for older engines. I think your mind is playing tricks on you though with the '10 @ 20k miles. You should be able to eat out of your intake manifold w/ that mileage. I have 85k miles and mine still runs great.
    Do your neighbors hate you now lol ?
    I seafoamed my sister's car once and she actually got pulled over because the cop thought her motor was about to blown.
  6. Mar 10, 2011 at 12:35 PM
    macgyver
    Brad
    Canton, GA
    You won't hydrolock it. I've done it a bunch of times to different cars and never had an issue.
  7. Mar 10, 2011 at 12:37 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    very easy to do, just follow the back of the can. youll be fine
  8. Mar 10, 2011 at 12:38 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Ha yea looked like the fog was rolling in. On the motor I took a section of gas line with the bulb, stuck one end in seafoam and pumped it straight in, worked like a champ
  9. Mar 10, 2011 at 12:39 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    would it be smart to do this to a 1997 with 165k miles?
  10. Mar 10, 2011 at 12:40 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Wouldn't hurt a thing. Always good to keep the engine clean. Remember 1/3 straight to engine, 1/3 in oil tank, 1/3 in fuel tank
  11. Mar 10, 2011 at 12:41 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Or a 2002 with 135K
  12. Mar 10, 2011 at 12:43 PM
    97yota4wd
    Eric
    Mesa, AZ
    i dont know what im doing with it... will the directions on the bottle say everything i need? and i heard someone say do it right before a oil change?
  13. Mar 10, 2011 at 12:43 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Anyone who has abused the hell out of their engine, or who is a little late on the oil change can benefit from this. It helps remove deposits left behind
  14. Mar 10, 2011 at 12:44 PM
    scocar
    scocar hypotenoper
    You know, i have still not done the induction process on mine, because I have one lingering concern; all that carbony crap that gets blown off the valves and cylinders needs to go downstream, and the expensive cat is...right in harm's away. Seems like it would contribute to the cat's early demise. Any thoughts or experience with this?
  15. Mar 10, 2011 at 12:44 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    yea it will. Locate the line on the left of the brake booster that goes straight to the engine. Crank up engine disconnect line from booster, slowly let it suck in, cut the engine off, wait 5 minutes, crank up, let it idle and then drive around
  16. Mar 10, 2011 at 12:45 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    i did this about 3 weeks ago on 4 different cars my wifes, honda civic with about 130k, my dad frontier with 50k, my bro's 97 taco with 210k and mine. did all through the vacum hose, and worked really great with the higher mileage cars mine should a little
  17. Mar 10, 2011 at 12:47 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Awsome I think I will get a can today and just do the line and wait to do the tank and oil. Will I have to change my plugs?
  18. Mar 10, 2011 at 12:48 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Pretend I'm a f*cking moron.... Explain this process step by step?
  19. Mar 10, 2011 at 12:49 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    it will work for any vehicle, its good stuff. i used it in my old s10 and it was fun watching all that smoke haha
  20. Mar 10, 2011 at 1:27 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Crank up engine, disconnect line from booster, slowly let it suck in the seafoam
    crank up again, let it idle a while and then drive around
