Wrangler Duratrac's for '09 Tacoma SR5 TRD
Discussion in 'Wheels & Tires' started by kingpeg, Jun 25, 2016.
  1. Jun 25, 2016 at 3:55 AM
    kingpeg
    kingpeg [OP] New Member
    Rob
    Nova Scotia
    2009 Tacoma SR5 TRD Off Road- Stock
    Hi
    I recently acquired an '09 stock Tacoma TRD (Off Road). It currently rides on 265 70R 16 tires.(all season)
    I wish to install Wrangler Duratracs-245 75R 16, to double as both a winter tire and off roading. I also haul a tandem trailer with a 4,000 lb tractor aboard.(very short distance only) I was wondering if, :
    1. The duratra's will fit with no lift or other changes
    2. Will the duratrac's be a good choice for my intended use
    Robert
  2. Jul 21, 2016 at 12:50 PM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    I'm thinking you mean 265/75R16 right? I have duratracs in that size on my '05 TRD OR and had to remove the front mud flaps.
    No towing experience with this truck but I live in Montana and pretty happy with these tires for the 22k or so I've had them. I mostly drive on road but they do very well in the mountains and snow. The only bad thing is that they are relatively loud on the highway but not terrible IMO. Mine are load range C.
  3. Jul 21, 2016 at 12:53 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I have a stock 2010 TRD Off-Road and the Duratracs in 265/75-16 fit just fine when I had them. Supposedly there is some rubbing on the mud flaps at full-lock but honestly I never really notice it or had any problem during the 55k miles I had them.
  4. Jul 21, 2016 at 1:55 PM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    My 265/75/16 Duratracs are on a 2011 DCSB TRD OR, stock rims, 3" lift. I've towed a 16' vintage Airstream travel trailer on a couple long trips. Gas mileage suffers a bit when towing, but the truck handles it just fine. With gear in the trailer, it's gross weight is around 4500lbs. The tires have a bit over 21,000 miles now. I religiously rotate tires, and keep accurate wear measurements. So far, just under 2/64ths inch wear. I'm 100% pleased with that. These tires went on BEFORE the lift and never once rubbed. They look great WITH the lift in case you ever decide to go that route. I run around empty with 34psi, but when the trailer is hitched up, closer to 40psi. Mine are the load range C's. If I was going to haul the trailer a lot, I'd go with "E's".
    With what I know about Duratracs, I wouldn't hesitate for a second to do the same thing again.
