Wrapped rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07Yota209, Jun 9, 2024.
  1. Jun 9, 2024 at 5:27 PM
    07Yota209
    07Yota209 [OP] Member
    Charles
    2007 Tacoma v6 4x4
    07' Tacoma 4x4
    Last brake and rotor replacement at 130k. Now at 167k. Never had rotor issues since buying new. The brakes are about 1/2 worn down.
    One thing to note is that I bought a boat in 2019, and truck is used a lot for towing. Boat is a 16' crestliner, about 1,800 lbs w/a trailer that's probably 500 lbs. I definitely brake harder with the boat behind me.
    I'm about to change out the brakes and rotors. Any recommendations on rotor brand and brakes?
  2. Jun 9, 2024 at 5:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Toyota gives us a lot of metal on these rotors.
    I've used both the the Advanced Auto Platinum and PowerStop standard rotors with good luck.
    I find the key is to not brake hard and then let the pads stay in one spot of the rotor too long.
    Stop short, creep up, stop, creep up. That way you aren't sitting there heat soaking one spot on the rotor.
    At least that has worked for me. And so far, I've never warped a set of rotors.
    FWIW, most "warped" rotors are not warped. It's pad material transfer.
    So good pads are a must too. It's not just rotors.
    Kwikvette likes this.
  3. Jun 9, 2024 at 5:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Easy, akebano pads.
    This time around I went with EBC greens, but when these wear out I'll go with akebano like I did on the 4R.
  4. Jun 9, 2024 at 6:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    Correct. Warped rotors needs to join the 3k mi OCI graveyard. :thumbsup:
    Seems reasonable to me. Lots of folks I ran with in solo II made the jump to EBC back in the day, but most didn't stay there real long. Not that they were bad, more that they didn't meet their marketing hype in competitive conditions.
    clenkeit likes this.
  5. Jun 10, 2024 at 5:45 AM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    Look for 2nd Gen Big Brake Kit -OEM parts- Part #s provided (INSTALLED) thread on this forum.
    I did this mod on my 2015 TRD Sport about 2 years ago, I pull a trailer quite a bit and this really helped
    reduce my stopping distance from speed. I replaced the splash shields, bought used calipers and rebuilt them,
    and used Brembo pads and rotors and did a complete brake fluid flush as well as stainless steel flex hose replacement
    at the same time. Still running the stock master cylinder and my brakes work great. Huge improvement over stock.
  6. Jun 10, 2024 at 6:28 AM
    07Yota209
    Charles
    2007 Tacoma v6 4x4
    I found the thread. I'm gonna give this a try.
    Thank you!
