Wrecked with $9k in damage.....input
Discussion in '3rd Gen. Tacomas (2016-2023)' started by reloader403, Dec 22, 2019.
  1. Dec 22, 2019 at 4:39 PM
    reloader403
    reloader403 [OP] Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Well, less than a month from getting rear ended I slid of the road and nailed a guard rail. Go me. I took it to a body shop that did a great job on my wife's toyota to see how bad it was.....they came back with $9k in damage. My biggest concern is my front right wheel was pushed back 1-2" and when taking it out of 4Hi it sounded rough....more like a sledgehammer to the transfer case would be more like it. I have 80k on the truck and it seems the third gens nose dive in value esp with a collision on the carfax. Im stressing out about when they get my truck fixed that theres an underlying issue in my drive train from the wheel situation. Its never sounded like that before, tested if a few times and it did it every time. Has anyone had a collision in their third gen that was this pricey? Any suspension or driveline issues?
  2. Dec 22, 2019 at 4:44 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Many have posted here with $20K+ in damages. Your value will be no worse or better than any other wrecked vehicle. You are right to be stressed... In all my years I have never witnessed a vehicle appreciate in value because it was in an accident.
    As far as noise, tell the shop and adjuster. They will make sure to check it and fix it if it was damaged in the accident. Good luck.
    LSUfan1975 and Chew like this.
  3. Dec 22, 2019 at 4:52 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Bummer, that's why we call them accidents, at least you not paying on you for an injury. 80 thousand on it, fix it, off road it, have fun.
  4. Dec 22, 2019 at 4:56 PM
    JS760
    JS760 Well-Known Member
    San Diego
    2017 DC Sport
    9k is not a lot of damage.
    MannyS and Hank Heel like this.
  5. Dec 22, 2019 at 5:50 PM
    Beau_Higgins
    Beau_Higgins Well-Known Member
    Do these as fast as possible:
    Get it fixed.
    Pay it off.
    Sell it private.
    Fat chance a private buyer even pays for a Carfax report and there are many folks that would salivate at a decently-priced Taco w 80k on it.
    Bronco comes out soon might end up being good timing for you if Ford doesn't screw it up.
  6. Dec 22, 2019 at 5:53 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Time to do a solid axle swap (SAS).
    Grossomotto and DG92071 like this.
  7. Dec 22, 2019 at 6:02 PM
    reloader403
    Acworth, GA
    Lol man I needed that, it's at the shop now and will be for 3-4 weeks.
    whatstcp[QUOTED] likes this.
  8. Dec 22, 2019 at 6:05 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I bet you broke a speed sensor. The transfer case always bangs when going back to 2 wd when a speed sensor is bad.
    Im sure you bend an a arm. It's supposed to do that in an accident. Still a cheap repair.
  9. Dec 22, 2019 at 6:12 PM
    reloader403
    Acworth, GA
    That's a good starting point to look in to when I get it back. Both upper and lower control arms and the spindle were trashed. Didn't even think a speed sensor being screwed too ...
  10. Jan 23, 2020 at 12:32 PM
    reloader403
    Acworth, GA
    Got the truck back and everything seems normal. The body shop did screw up a few things that weren't worth splitting hairs over. Hopefully long term everything stays peachy.
    koditten likes this.
  11. Jan 23, 2020 at 12:37 PM
    Duezzer
    Duezzer Well-Known Member
    Glenn
    2019 Cavalry Blue TRD Sport
    Some - Will list later - has lift and new wheels and rubber
    Great to hear.
