Wrenching on gravel/dirt/grass tips and tricks
Discussion in 'Garage / Workshop' started by truckbeans, Mar 22, 2019.
  1. Mar 23, 2019 at 8:49 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    They sell smaller blower heaters. They do suck down the fuel, though. I have a small propane unit but only use when I must.
  2. Mar 29, 2019 at 8:11 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Its hard to beat cardboard. I keep it in my garage too for when i do oil changes. Less worry about spills and splatters. Its usually cleaner than my concrete floor as well, so less worry about getting back in the truck when there could be dirt on the back. I also keep lots of zip loc bags around for screws. You can also use a bunch for different groups of screws.
    CygnusX191 and truckbeans[OP] like this.
  3. Mar 29, 2019 at 8:16 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
  4. Mar 29, 2019 at 8:21 AM
    truckbeans
    truckbeans [OP] Well-Known Member
    Kent
    Sylva, NC
    2018 DCSB OR
    OME 887s, nitrochargers all around, Headstrong progressive add-a-leaf, 255/85-R16 Yokohama Geolandar M/T, Full set RCI skids, RCI sliders, SOS Slimline w/ Smitty 10k winch
  5. Mar 29, 2019 at 8:22 AM
    Micatom33
    Santa Cruz,CA
    2008 BSP DCSB
    yea snag them from the kids I did :spy:
    doublethebass and CygnusX191 like this.
  6. Apr 8, 2019 at 12:53 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I used plywood so easy to move the jack instead of fighting to move it over stones etc
    Big help on clutch changes.
    plywood pieces for the jack stands at least 12"x12" nothing like lowering the vehicle and it goes sideways
    If you live where it freezes nothing like having things thaw and the vehicle fall off the jack stands when you leave for some reason.
    It never fails even having the nicest shop something that should take minutes you decide to do outside try not to block your doors because a few minutes becomes a few days . Most likely a Blizzard or Hurricane as well.
    If hardware is involved I will lose a few pieces having a JIS bolt assortment saves so much frustration
    wilcam47 and truckbeans[OP] like this.
  7. Apr 17, 2019 at 3:45 PM
    Pyrotech
    Pyrotech Well-Known Member
    many years ago, before i had a nice cement surface to work on, I had an old cutlass that was getting a small block conversion. and in the process I had the engine in and out several times. No working on a gravel driveway with a cherry picker, made it ... how should say... difficult.
    Luckily dad had recently picked up a truck load of 4'x8' 3/16" steel plate. hmmm if you can't have a nice concrete slab, Steel does work too
    laid a sheet down under the car and used it as a smooth surface for.
    I had an old throw blue throw rug that also came in very handy, when working outdoors in the dirt.
    CygnusX191 likes this.
