Write Up: Badge Removal, painting, and reapplication
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nrm, Dec 14, 2010.
  1. Dec 14, 2010 at 1:59 PM
    nrm
    nrm [OP] Well-Known Member
    NC
    2011 4.0 DCSB TRD Off-Road
    4-leaf TSB and Eibach 620 coils with Bilstein 5100's set to 0". AFE intake and Gibson cat-back exhaust. Bestop canvas topper
    So I know there seem to already be a lot of people who have done this, but I also keep seeing people talking about breaking their badges in the process of removing them. I figured as a new member, I'd do my part to contribute and document my 1st mod to my new truck...It's a work in progress as I'm not completely done, but I'll continue to update.
    1st-get a hair dryer and some heavy duty fishing line. I don't know what gauge this is but if it's too thin (like the first type I used) it will just continue to snap in half.
    Then heat up the badges
    Starting at one end, just use the fishing line like floss and slide it back and forth
    http://s720.photobucket.com/albums/ww202/nrmulherin/4runner/?action=view&current=PC140438.mp4
    It seriously took me 15 minutes to get all the badges off once I had a strong enough fishing line, it's really simple. Since my truck is brand new, the leftover adhesive was very easy to just rub off by hand as well
    I'm painting mine black so I first sanded all the badges to rough up the chrome and allow the primer to adhere a little better
    Also make sure to remove any leftover adhesive on the back of the badges before you start painting, this way you don't have to be trying to scrape crap off and worry about messing up the paint job. A razor blade worked perfectly for this
    I'm using a rustoleum automotive primer, krylon fusion, and a valspar satin clear coat. I'm also painting the front emblem, but using the flat black rustoleum, with the glossy rustoleum clear coat.
    So that's what I've got for now. About to apply the final satin clear coat layer and will wait to reapply to the truck until tomorrow, but will post more pics once I get them on.
  2. Dec 14, 2010 at 2:03 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Looking good. Same way I did mine.
  3. Dec 14, 2010 at 2:08 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    JUST FYI for Others:
    If the excess adhesive doesn't come off the truck easily, I recommend the 3M Stripe Off Wheel, takes it off in seconds.
  4. Jan 6, 2011 at 8:57 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    What kind of adhesive to use when you reapply?
  5. Jan 6, 2011 at 9:24 PM
    nrm
    NC
    3M double sided molding tape. You should be able to get it at most automotive stores or Lowes/Home Depot.
  6. Jan 6, 2011 at 9:34 PM
    toothaker1219
    toothaker1219 Well-Known Member
    For lighter colors, I would advise put the tape on the back side of the emblem, cut out the parts that would show (crevasses), paint, remove red backing and stick back on.
    That way you don't see black in-between the letters that don't need to be there
