*write up* hood scoop removal and dis-assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Detective_Dan, Mar 9, 2013.
  1. Jul 14, 2015 at 1:37 PM
    #61
    Creole Knight
    Creole Knight Man's got to know his limitations.
    Ulysses
    So. Cal
    05 Super White PreRunner
    gear shift knob and other things.
    I like this Mod I should have done it years ago but better late than never. I live in So. Cal. so it's more hot than anything and sitting in traffic kills your engine with heat build up so I think it is worth the little time to do it, hell I added a aux fan in the front of the a/c condenser with a switch in the cab to deal with the heat. I wash my engine all the time never had a problem the little water that might get in through the scewp is not a factor. Nice write up OP thank you.
  2. Mar 28, 2016 at 6:46 AM
    #62
    Rickhead
    Rickhead Active Member
    SW Washington
    2011 Tacoma TRD Sport
    I just ordered an 11" LED light bar for the fake scoop. Hopefully it fits :fingerscrossed:.....If not I will be forced to buy a matching light bar and mount them under the grill! Then buy a smaller one for the scoop hole! :yes:
  3. Nov 21, 2016 at 5:28 AM
    #63
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I was thinking the same thing Rickhead, got a slim 11 inch bar for it but haven't installed it yet. Did yours fit and how did you mount it? Dont let people bother you about the opening OP, opinions are like assholes...
  4. Nov 21, 2016 at 7:36 AM
    #64
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Well, I for one think this is a great mod, might even do it myself but why did they design it to be nonfunctional? Just wondering is all.
    kimo and Fastbilly5 like this.
  5. Mar 5, 2017 at 1:26 PM
    #65
    PhilC
    PhilC Member
    Phil
    Indianapolis, IN
    06 Tacoma TRD Sport
    Just drilled the rivets out, threw some primer on the mesh and going to grab some stainless hardware to finish it off. Thanks for the suggestion!
  6. Mar 7, 2017 at 6:47 PM
    #66
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  7. Feb 4, 2018 at 9:09 AM
    #67
    Geotech Guy
    Geotech Guy Na Zdraví!
    '04 Taco 4x4 TRD Off-Road / '15 Taco 4x4 TRD Pro
    '04: gray wire mod and battle scars. '15: none yet!
    Mine appears to be a single molded plastic piece, as well, so no-go. 2015 TRD Pro.
  8. Mar 27, 2018 at 2:14 PM
    #68
    jkowal20
    jkowal20 Well-Known Member
    Joey
    2015 White Tacoma TRD Sport
    Thanks for the pics, helps a lot!
  9. May 17, 2018 at 5:06 AM
    #69
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Anyone mod the scoop to direct into aircleaner?
    Guess you'd be constantly cleaning your filter, but engine would sire get more cooler air.
    Might give it a power boost?
    Dirty Scotty likes this.
  10. Aug 25, 2018 at 2:45 AM
    #70
    justcuz
    justcuz Well-Known Member
    this might help some of you
  11. Jan 18, 2019 at 10:00 AM
    #71
    Busted'90 4runner
    Busted'90 4runner New Member
    2016 Taco TRD
    bone stock
    I've been wondering if removing the plastic was worth it, seeing both sides in the comments. Thank you for going through this step by step.
  12. Jan 11, 2020 at 2:50 PM
    #72
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Nice straw man argument but in every one of those they had a sealed airbox with filter. It didn't allow crap to pile into the engine compartment. Whatever floats your boat dude its your mess.
