WRITE UP: UNICHIP Programmer
Discussion in 'Product Reviews' started by BrokenTusk, Sep 30, 2011.
  1. Sep 30, 2011 at 8:36 AM
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    UNICHIP Programmer - Write Up
    **This used to be my for sale thread, it has been repurposed for UNICHIP information. Everything I know is listed below, feel free to PM me with a question if it hasn't been answered after you've read below**
    Unichip programmer is 100% Plug and Play, installs in 10 minutes. Removes just as easily.
    There are 2 types for the 2nd Gen Tacoma's, the first fits years 2005-2008. The 2nd fits years '09+
    The one that fits 2nd Gen Tacoma's 2005-2008, UNICHIP has told me that the chip's software can easily be updated to work with the 09+ V6 Tacoma's, BUT The physical wiring harnesses are incompatable. They also said they are willing to change out the wiring harnesses for the low low price of 277$....
    Please read on for more info
    The UNICHIP has served me great. It does have its limitations, My issue with it is that its like an apple product. Its super easy to plug in and play and use. But if you wanna start custom tuning it, you gotta buy the UNICHIP tuning software and the UNICHIP personal tuning trainer(the one that teaches you how to use it) software.
    Its a "closed" system as they say, only works with the special software from UNICHIP themselves. OR you can just find a unichip certified tuner, which is your way better and way cheaper option, if you have a tuner in your area then your good to go. None of which exist in Canada,something I neglected to check before I bought mine. I ran it fine for a year plus (about 14 months) with no issues, the standard map that came with it served me well.
    I originally went the unichip route because they are meant to be fully upgradeble, and can eventually support S/C and Turbo if thats your goal. Or if you are knowledgable enough to tune it yourself, then get the software and the skies the limit for ya. Me personally I don't have enough experience with that sort of stuff.
    When you buy your chip, you have the option of selecting one of the pre-tuned maps for whatever additional intake and/or exhaust upgrades you might have. If you get it tuned to your vehicle specifically, then you can crank another 9-13 hp out of it. This is the difference between what they call a "Standard Map" and a "Custom Map". (Custom meaning when you have it tuned specifically for your vehicle versus the standard map that UNICHIP loads onto the chip at purchase.)
    Heres my dyno threads, also just an FYI, my dyno was messed, turns out later I found out the guy who did my dyno had only used the machine once before.
    Heres the 2 threads with all the info, read all of it and the comments as we figured out what happened:
    http://www.tacomaworld.com/forum/per...-happened.html
    the Xr-u.com one is better, more tuner guys over there:
    http://www.xr-underground.com/forum/...ad.php?t=42651
  2. Oct 1, 2011 at 7:30 PM
    HomerTaco
    HomerTaco Chillin & Grillin Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    BIG BUMP FOR MARCEL!!!! :D
  3. Oct 1, 2011 at 9:10 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :eek:
    :thumbsup: :woot:
  4. Oct 6, 2011 at 6:29 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I believe that 09+ will need a different ECU pigtail then the 05-08. At least that was my understanding when I was researching this a while back.
  5. Oct 6, 2011 at 6:46 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Still trying to confirm this, UNICHIP hasn't answered my e-mail so i'll probably call them later
  6. Oct 11, 2011 at 10:26 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Original Post updated with UNICHIPS support info for the 09+.
    Here it is just for reference:
    Fits 2nd Gen Tacoma's 2005-2008, UNICHIP has told me that the chip's software can easily be updated to work with the 09+ V6 Tacoma's, BUT The physical wiring harnesses are incompatable. They also said they are willing to change out the wiring harnesses for the low low price of 277$.... :pout:
  7. Oct 11, 2011 at 8:01 PM
    HomerTaco
    Craig
    Bucks County Pa.
    Marcel bump... :spy:
  8. Oct 12, 2011 at 2:53 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    i would have been all over this but.... i put my downpayment on my supercharger kit this past week :D
  9. Oct 16, 2011 at 7:41 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  10. Oct 16, 2011 at 8:02 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    I think I might bite the bullet on this........ PM sent
  11. Oct 16, 2011 at 8:59 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  12. Oct 16, 2011 at 9:53 AM
    HomerTaco
    Craig
    Bucks County Pa.
  13. Oct 16, 2011 at 11:03 AM
    hitmans.army
    Myrtle Creek, OR
    I'll take it. I seem to be spending lots of money today. Now just need HomerTaco to say he wants my money and I will have everything I need.... Then I can go onto the lower priority needs (wants). LOL.
  14. Oct 16, 2011 at 11:16 AM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Lol, he's pretty good at that he took mine too :eek:
  15. Oct 16, 2011 at 11:30 AM
    hitmans.army
    Myrtle Creek, OR
    $ sent. But it didnt give me a place to put comments or anything else.
  16. Oct 16, 2011 at 2:12 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    SOLD to the Army of hitmans :thumbsup:
  17. Oct 16, 2011 at 2:33 PM
    HomerTaco
    Craig
    Bucks County Pa.
  18. Oct 16, 2011 at 2:35 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :woot: Agreed, it'll free up some closet space, trying to downsize my life ATM
  19. Oct 16, 2011 at 2:46 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    ill give u 150 shipped
  20. Oct 16, 2011 at 2:47 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    It's going to be shipped out tonight to the buyer haha, but if you really want to be parted with your 150$ so much you can just send it to me anyways :cool:
