Write Up: Working Airbags and Occupant Detection System with Aftermarket Seats
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kelson, Jun 7, 2011.
  1. Jun 7, 2011 at 12:50 AM
    Kelson
    Kelson [OP] Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    How To get the Airbag system working w/ aftermarket seats.
    Step One: Flip bench over to reveal airbag wires. The wires are all in a loop, it’s just a matter of removing clips and zip-ties. You must disconnect the plug for the occupant detection system on the passenger side. Label EVERYTHING!
    Step Two: Using a Phillips screwdriver, remove the passenger occupant detection computer.
    Step Three: Remove the occupant detection thing. It’s a thin plastic air bladder that sits in between the cushion, a hard plastic layer, insulation and the metal support springs for the seats. Reach in between the plastic hard plastic layer and the air bladder and feel towards the front of the seat. There should be two plastic clips holding the air bladder. Reach for them and rip dat faka out. It is possible to take it out without ripping the small top portion off, but not nessecary as it has nothing to do with the actual occupant detection system; it’s just there to hold it in place.
    Picture of the occupant detection system. The two connection points to the seat are circled in green
    Undoctored photograph
    Step Four: Re connect all harnesses to their appropriate locations, seatbelts, to the truck, occupant sensor and its computer. There are also two grounds that need to be grounded.
    Step Five: Hide underneath carpet, or do whatever you want with the gaggle of wires you now have. Find a place to mount the occupant detection system. I chose to put it on top of the passenger seat as they will be covered in the future.
    Step Six: Enjoy your working airbags and passenger occupant detection systems!
    t1m829 likes this.
  2. Jun 7, 2011 at 2:22 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    great write up
  3. Jun 7, 2011 at 2:43 PM
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    man that is awesome! great step by step write up!
    now to find some seats
  4. Jun 7, 2011 at 6:09 PM
    Boring
    Boring This space unintentionally left blank.
    Arizona
    5-lug regular cab
    yarp
    So, this probably applies to 05-08 regular cabs without bucket seats...
    Thanks for the writeup Kelson.
    I did not know there was a butt computer too. Gah! Thanks Toyota. :rolleyes: No freaking wonder the buckets cost $2,000+ each. I was flirting with the idea of trying to transfer buckets into mine too. Now I'm less sure than I was before. I'm really tempted to just sell it and get the extended cab with the buckets already installed. The bench makes me fidget like a 2 year old on drugs.
  5. Jun 8, 2011 at 1:01 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    lol i'm pretty sure if you can find 09+ buckets with the airbags, there probably is a way of swapping them. but prob pretty hard, as im sure there are more sensors in them then the 05-08 seats without the airbags, as they only have seatbelt and ass detectors lol
  6. Nov 16, 2011 at 10:35 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I did the same thing bro, I'm trying to locate an OEM passenger airbag on/off switch/plastic so I can bypass the stupid passenger seat bladder. The bladder is filled with an oil, when you sit on it, it puts back pressure on the switch which activates the passenger airbag. I'm going to splice those wires and use the OEM passenger airbag on/off switch instead!!
  7. Nov 16, 2011 at 10:46 PM
    TacomaBuzz
    CT
    the earlier 2nd gen tacoma's came factory with the keyed passenger airbag on /off switch which was replaced with the bladder. I already installed the resistors to bypass the side curtain airbags and transplanted the computer occupant detection system wires/ seat buckles/ sensors. the only thing I need is that switch . I destroyed the bladder trying to remove it, oil all over the floor, LOL.
  8. Nov 16, 2011 at 10:56 PM
    TacomaBuzz
    CT
    Sounds good man, keep me posted and vice versa! We'll get this sorted out seeing as we both have the same dilemma.
  9. Nov 16, 2011 at 11:55 PM
    TacomaBuzz
    CT
    ^ Pretty much says everything we already know, Can't expect Toyota to write a DIY on how to bypass airbag hardware, LOL
  10. Jul 23, 2012 at 9:45 PM
    pinktaco808
    pinktaco808 Hot Steppa
    you never show re-installing the bladder in the new seats.where did you place them?
  11. Aug 19, 2013 at 6:04 AM
    Kavik
    Kavik Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    subed
  12. Mar 1, 2014 at 4:00 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Saving
  13. Jan 15, 2015 at 8:17 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    So how can we override the seat airbags completely? I really want Corbeaus but I have OEM in-seat airbags...and I didn't see anything here to transplant the airbag, just the occupant sensor :notsure:
    :blahblah:
  14. Jun 1, 2018 at 9:27 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  15. Jul 8, 2018 at 4:14 PM
    pinktaco808
    What about the seat belts
  16. Sep 4, 2023 at 12:23 AM
    hayrider2.0
    hayrider2.0 Over the hill and going down fast!
    Hey You
    2 Centimeters from Hell 200 Miles from Water
    05 & 07 White Reg. Cabs w/ sticks
    05 Magnuson 07 LS Swapped
    pinktaco808 and t1m829 like this.
