Wrong coolant, now what
Discussion in 'Technical Chat' started by 270Fan, Dec 3, 2018.
  1. Dec 3, 2018 at 12:45 PM
    270Fan
    270Fan [OP] Member
    Jack
    Southern California
    2015 Tacoma TRD doublecab
    My 17 year-old son has a 2000 Tacoma V6. About 6 weeks ago it started leaking coolant, he found a crack in the radiator. Like a knucklehead (and without my knowledge) he continued to drive it a couple miles a day. When I learned he was driving it I hollered at him to park it until he could afford the parts to fix it. The radiator was actually dry, fortunately it was literally less than 2 miles a day.
    I had to go out of town for a few weeks because my father died and had to take care of my mother. While I was gone my son filled up the radiator with Peak 50-50 antifreeze for Asian vehicles. Problem is he used the BLUE instead of the PINK. When I heard about it I hollered at him again and told him to park it. I plan to drain it and flush it this weekend before I replace the radiator and hoses. Other than that, is there anything else I need to do? Hoping there isn't some significant damage incurred. Any help is appreciated.
    JayRolla likes this.
  2. Dec 3, 2018 at 12:56 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    I imagine that it's nothing a cooling system flush wouldn't fix if it hasn't been in there for very long. Shouldn't be that hard if yourey replacing the radiator.
    270Fan[OP] likes this.
  3. Dec 3, 2018 at 12:58 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    yeah you don't want to mix different kinds of coolant. Most recommend the OEM Toyota pink stuff but you can run other kinds, just don't want to mix them.
    Doesn't sound like he drove it much with it mixed so I'm sure it's OK...I'd be more concerned with it possibly being overheated since it drove it with very little coolant.
  4. Dec 3, 2018 at 12:59 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It's blue to mimic formulas like the OEM Honda coolant. It's just coloring. Nothing to worry about. But if it's something that bothers you, drain it out and start fresh.
    No damage from the blue Asian formulas. You can relax :thumbsup:
    Lester Lugnut and 270Fan[OP] like this.
  5. Dec 3, 2018 at 1:02 PM
    Plain Jane Taco
    USA
    BTW....you can buy Valvoline Zerex in the Toyota pink color at Walmart for around $12. It's premixed and is a HOAT formula.
  6. Dec 3, 2018 at 1:28 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I agree a system flush and refill with the correct pink SLLC coolant will do it right.
    I've used the Valvoline pink coolant "for asian vehicles" and I haven't had any problems. https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-Ready-To-Use-1-Gallon/49660461
    Lots of people say this (and the Zerex for asian) is nearly the exact formulation as the more pricey Toyota stuff. Although next time I might pony up a few more dollars just for peace of mind.
    Good luck... although your kid should have asked you first, I think it's good that he is trying to fix stuff :D
  7. Dec 3, 2018 at 1:28 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Your fine. It's the same formula just different color. I've been running blue in my 4runner for many years because it's all that I could find locally and kept using it.
  8. Dec 4, 2018 at 8:38 AM
    270Fan
    270Fan [OP] Member
    Jack
    Southern California
    Thanks everybody for the input, very much appreciated. My son also thanks you, now he will not have to learn to walk with a limp. :D
    Plain Jane Taco likes this.
