Wrong diff drain gaskets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saskcan, Nov 11, 2021.
  1. Nov 11, 2021 at 9:29 PM
    saskcan
    saskcan [OP] Well-Known Member
    Curtis
    Saskatchewan
    2010 sport 6spd
    some accessories
    Had real diff axle seal replaced and had shop change front and rear diff fluid. I supplied fluid and gaskets (in bag was gaskets for oil drain, rear and front diff etc) anyway I noticed they put transfer case drain gaskets on rear drain and fill plugs. Is this any concern? I back a boat in the water frequently In summer so water contamination is a concern. Thanks for any advice
  2. Nov 11, 2021 at 9:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    All those 24 mm drain/fill plugs have the same gaskets
    TnShooter and saskcan[OP] like this.
  3. Nov 11, 2021 at 9:36 PM
    Bishop84
    Bishop84 Well-Known Member
    Nah its fine. They are interchangeable no issue.
    Ideally you want the crush style on the diffs and the solid aluminum on the tcase, but it will 100% seal and you have no issues.
    saskcan[OP] likes this.
  4. Nov 11, 2021 at 9:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check this out if you're worried about water in the rear axle
