Wrong grease, what will happen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tumbleweed76, Sep 9, 2022.
  1. Sep 9, 2022 at 3:21 PM
    Tumbleweed76
    Tumbleweed76 [OP] Member
    2016 Tacoma TRD OR
    Full skids, rock sliders, two and a half inch suspension lift, New leaf pack and add a leaf in the rear.
    So I have icon upper control arms. The tubular kind with the Delta joint closest to the wheel. The two back bushings are regular high heat high pressure red grease on the zerk fittings. The front zerk fitting with the Delta joint is supposed to be a white lithium grease for the polymer bushing. The guy working on my truck put regular red Grease in that polymer bushing. What will happen and what should I do?
    Thanks
  2. Sep 9, 2022 at 3:37 PM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    Prayers sent. It’s totaled.
  3. Sep 9, 2022 at 3:40 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    It will turn pink.
  4. Sep 9, 2022 at 3:41 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Red n tacky #2 is still a lithium grease.
    You just peppermint palace-d your bushings. But that's about it.
    Tumbleweed76[OP] and Steves104x4 like this.
  5. Sep 9, 2022 at 3:42 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    :bananadead:
    Unless Icon says otherwise, like whatever grease was put in there will deteriorate the materials used in the delta joint, which I highly doubt, I wouldn't worry about. If you are & if you have a grease gun with the correct grease just pump that in there to flush out the other grease.
    Shit it's Friday, I can't tell when some threads are serious or not anymore. :rofl:
    Tumbleweed76[OP] likes this.
  6. Sep 9, 2022 at 3:48 PM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    The new grease will react, causing breakdown of rubber and metal components, they make a connector to suck out the bad/wrong grease. It’s called yourpride, make sure to post results.
    Happy Friday.
  7. Sep 9, 2022 at 3:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
