Wrong grease?
Discussion in 'Technical Chat' started by 186000mps, Mar 14, 2012.
  1. Mar 14, 2012 at 7:43 AM
    186000mps
    186000mps [OP] ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    Just changed the oil on the 4Runner and thought it would be a good idea to grease the drive shaft (ha ha). I did not have a grease gun suitable for the zerks, so I went out and picked one up. I filled it with Lucas lithium Red 'N Tacky #2. Later I realized it is NGLI rated but no number following.
    Will this be too soft to use?
    Also I saw noted that the double cardan joint uses a moly fortified NGLI 2 grease. How many folks use a separate grease for this? and what is the advantage mechanically?
    Is the Red N Tacky okay to use or should I ditch it?
    Thanks
  2. Mar 14, 2012 at 9:48 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ same for most dealerships.
  3. Mar 14, 2012 at 10:05 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    damn I use water proof bearing grease. Thats what is usually in my greese gun. N =ot sure if thats good or not:confused:
  4. Mar 14, 2012 at 10:11 AM
    OffroadToy
    I just use lithium base nlgi #2 for everything
  5. Mar 14, 2012 at 10:30 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Thanks guys!
  6. Mar 14, 2012 at 10:44 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I use mobil 1 on everything...from wheel bearings, UCA zerks, Tie rod zerks, BJ zerks, axle zerks. No complaints so far. time will tell
  7. Mar 14, 2012 at 10:57 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Same mobil 1
