Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 14, 2022 at 7:54 AM
    bobbysk123
    bobbysk123 [OP] Well-Known Member
    bobby
    2020 toyota tacoma TRD off road DCLB 4x4
    N/A
    My dad was a master tech at toyota, now has his own shop for 10 years (he thinks he's smarter than the toyota engineers). I gave him my 2020 tacoma and he started putting 30w10 instead of 0w20 to save money and i told him (0w20 doesn't even cost more than 20 bucks if you really hurting for money i'll buy it) he blantly refused. He complains that he only gets 9 mpgs (it's lifted on 33s) and a couple weeks ago, the engine crapped out and he blamed me. Trying to figure out if it were the oil or maybe something else. But if it's not the oil he's going to try to make me pay for the rebuild. Is the engine going out pre 50k miles a common thing on the tacoma or could it be (maintenance issues)?
  2. Nov 14, 2022 at 7:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm confused, is it your truck or his? If he's the one that made the decision to put in the wrong oil, even after corrected, that's 100% on him.
  3. Nov 14, 2022 at 7:57 AM
    Bishop84
    Bishop84 Well-Known Member
    Still under warranty, so it doesn't matter.
    Skydvrr, BRBNNEAT, zoo truck and 6 others like this.
  4. Nov 14, 2022 at 7:58 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Gonna need more details on how the engine failed.
  5. Nov 14, 2022 at 7:58 AM
    bobbysk123
    bobby
    N/A
    It's mine, but he uses it/"maintains" it. Since i've been out of country, i left it in his hands.
    CygnusX191 and disel_V1 like this.
  6. Nov 14, 2022 at 7:58 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I think you meant 10W30. But yes. That is way to thick of oil. And in cold weather it would be too thick to pump through the super tight bearing clearances. And would wipe out the bearings.
  7. Nov 14, 2022 at 7:59 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    What?
    Not sure what you are asking but one oil change with 10w30 didn't cause the engine to blow up.
    What happened to the engine?
    davidstacoma, MR E30, Auzea and 9 others like this.
  8. Nov 14, 2022 at 8:00 AM
    bobbysk123
    bobby
    N/A
    Nope, been doing that for a year
  9. Nov 14, 2022 at 8:02 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That makes sense, I should've put two and two together.
    I car sat/drove my in-laws car for half a year and maintained it as well. At the end of the day, it's not my car, it's theirs. I ran all maintenance decisions by them and handed them back the keys to a clean, well maintained vehicle. I'd expect nothing less from your dad too. It's one thing to make a decision to use the wrong oil on your own car, but to use it on someone else's car and then ignore their request to use the correct oil is absurd. Now, I'm not saying that that's what caused it, but at 50k miles the engine shouldn't be failing as long as it's had routine oil changes.
  10. Nov 14, 2022 at 8:03 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I'd find a new dad. And then find a new truck.
  11. Nov 14, 2022 at 8:04 AM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    If Toyota investigates and finds out about the wrong oil, they will deny the warranty claim.
  12. Nov 14, 2022 at 8:04 AM
    fourfourone
    It is a thicker oil but it not that drastic to cause the pump to starve to engine of oil lol.
    These motors should have no issue running 10w30 even in cold weather.
  13. Nov 14, 2022 at 8:05 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    This sounds like a healthy relationship.
    Rebuild it and keep it away from him from now on.
  14. Nov 14, 2022 at 8:05 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Unless of course they test the oil…
  15. Nov 14, 2022 at 8:05 AM
    bobbysk123
    bobby
    N/A
    Rod knock, then
    It's had multiple problems, such as rod knock and overheating, so my dad deemed it a POS. It finally blew a headgasket and warped the heads. Not sure what i'm going to do. I don't want to pay for the repair, if it is under warranty and there is no way the dealership can test the oil, i might be in the clear
  16. Nov 14, 2022 at 8:06 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It still falls under warranty since the factory powertrain warranty is 5 years/60k miles. Whether or not they'll be able to tell about the oil, I have no idea. Best of luck with everything.
    Gunshot-6A likes this.
  17. Nov 14, 2022 at 8:10 AM
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    Engineers are smart, if they call for a thin oil it's because the oil system needs that to maintain proper lubrication in the design. It's just that simple. Don't tell them what oil was put in it, it's unethical but it is what it is. It had oil and was maintained...technically.
  18. Nov 14, 2022 at 8:12 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    How the fuck do you blow the head gaskets warp heads and get rod knock in a 30-40k truck. Is the dude made of money? None of this makes any sense.
    Rusty66, G2.M6, photogr4x4 and 19 others like this.
  19. Nov 14, 2022 at 8:13 AM
    fourfourone
    I'm lost too haha
  20. Nov 14, 2022 at 8:16 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Your dad should probably walk, not drive.
