Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 15, 2022 at 9:50 AM
    #301
    eurowner
    eurowner Duke Sky
    Scoty
    The engine is stock..... The supercharger bolts to the stock engine.....
  2. Nov 15, 2022 at 9:51 AM
    #302
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Better mix it with some Aunt Jemima....
  3. Nov 15, 2022 at 9:53 AM
    #303
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    No fake crap maple syrup and peanut butter! Good stuff!
  4. Nov 15, 2022 at 9:54 AM
    #304
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I said that a little prematurely in the thread. At this point, I don't think the dad is the problem. If I were Dad, I'd find a new son; then find a new truck :anonymous:
    CygnusX191 and ToyoTaco25 like this.
  5. Nov 15, 2022 at 9:54 AM
    #305
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
  6. Nov 15, 2022 at 9:56 AM
    #306
    JoeT4R
    JoeT4R I don't have a Taco
    Joe
    NOVA
    '01 4R, SR5 4WD
    Well to be fair, I read pages 1 and 2, and skipped to page 16 and realized this is why we can't have nice things around here. I have no idea what happened. We went from engine failure to maple syrup, although I can understand why that was brought up. But you're a funny dude! :cheers:
  7. Nov 15, 2022 at 9:59 AM
    #307
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    For some reason I think tomorrow is Saturday!
    Pancakes with maple syrup and peanut butter and sausages!
    maybe an oil change?
  8. Nov 15, 2022 at 10:04 AM
    #308
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    So @bobbysk123
    What did you do to make 33s fit? I need it to crawl the speed bumps in my local mall and the big potholes on the roads.
  9. Nov 15, 2022 at 10:07 AM
    #309
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Missed the good stuff
  10. Nov 15, 2022 at 10:13 AM
    #310
    dnlskier
    17' TRD SPORT MT
    LOL!! I live in NH and help a good friend on my FD tap ~3500 taps, which we got about 550 gallons of syrup last season. One of my jobs is the fire box, talk about heat...
  11. Nov 15, 2022 at 10:15 AM
    #311
    wilcam47
    Will
    Bourbon state
    6" rough country block/spacer lift
    RicerRabbit[QUOTED] likes this.
  12. Nov 15, 2022 at 10:21 AM
    #312
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  13. Nov 15, 2022 at 10:24 AM
    #313
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    That can only be possible if using an oil viscosity way higher like 50w, otherwise i don't see even 10w-30 causing any issues.
    wilcam47 likes this.
  14. Nov 15, 2022 at 10:41 AM
    #314
    clip
    VA
    15 OR
    Not that we care about the oil discussion any more, but depending on the 10W-30 shear stability it probably sheared to a 20wt after master tech dad was done beating on it. Thus, it would work itself into the "tighter tolerance" bearings. Although with the rod knock, I'm not sure how tight those tolerances are any more - probably measurable with a tape measure.
    ToyoTaco25 likes this.
  15. Nov 15, 2022 at 10:43 AM
    #315
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Good time to talk about transmissions.....
    https://youtu.be/Ac7G7xOG2Ag
  16. Nov 15, 2022 at 10:44 AM
    #316
    clip
    VA
    15 OR
    I give that an 8/10 - if he had been chain smoking Lucky Strikes it'd get full marks.
  17. Nov 15, 2022 at 10:48 AM
    #317
    RicerRabbit
    Itz JDM tyte, yo!
    Oh jeez, thanks! Maybe I don't need to do a CMC with my -38 offset :eek:
    wilcam47[QUOTED] likes this.
  18. Nov 15, 2022 at 10:48 AM
    #318
    zoo truck
    None
    I did not know toyota builds special 3.5 engines just for use in mexico to use a higher viscosity oil. I guess our southern states that border mexico are a much colder climate they have different engine clearances that can't use the same oil viscosity.
  19. Nov 15, 2022 at 10:50 AM
    #319
    clip
    VA
    15 OR
    They get manuel transmissions too.
  20. Nov 15, 2022 at 10:57 AM
    #320
    RicerRabbit
    Itz JDM tyte, yo!
    Damn I'm jealous. A manuel transmission truck would be more engaging than my manual transmission truck.
