Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 21, 2022 at 5:26 AM
    #701
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    More like the 60's.
    CygnusX191[QUOTED] likes this.
  2. Nov 21, 2022 at 5:34 AM
    #702
    Vmax540
    Chuck
    Clarion PA.
  3. Nov 21, 2022 at 5:43 AM
    #703
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
  4. Nov 21, 2022 at 5:47 AM
    #704
    Buster Saunders
    Buster Saunders Well-Known Member
    Buster
    Blue Ridge Mtns, Va
    2023 Tacoma TRD Pro, Solar Octane, 6MT
    CygnusX191 and wilcam47 like this.
  5. Nov 21, 2022 at 5:48 AM
    #705
    Buster Saunders
    Buster
    Blue Ridge Mtns, Va
  6. Nov 21, 2022 at 6:12 AM
    #706
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    We did that back in the day with carb engines when the would start pinging too much. It works to steam the carbon off the heads, and pistons. I've use seafoam now instead.
  7. Nov 21, 2022 at 6:32 AM
    #707
    General Chaos
    General Chaos I like pie.
    Joe
    NC
    2022 MGM Tacoma OR TRD 6MT
    This is on the YouTubes, dude…you can totally trust it.
  8. Nov 21, 2022 at 6:39 AM
    #708
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
  9. Nov 21, 2022 at 7:19 AM
    #709
    Vmax540
    Chuck
    Clarion PA.
  10. Nov 21, 2022 at 7:55 AM
    #710
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    It's actually pretty well known that this works. It also works with coolant. Ever seen the piston of a motor with a failed head gasket?
    Not sure I would do it because cleaning carbon is generally unnecessary unless the build up is extreme (causing valve closing issues, piston ring seizing/clogging, etc). The Italian tune up works well enough :burnrubber:
    wrightme43, US Marine and 3JOH22A like this.
  11. Nov 21, 2022 at 8:08 AM
    #711
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
  12. Nov 21, 2022 at 8:42 AM
    #712
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's known that it works short-term and fouls up long-term. But if you want to steam load your piston rings go for it. Keep your mechanic happy and employed
    ToyoTaco25 likes this.
  13. Nov 21, 2022 at 8:47 AM
    #713
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    LOL! Thread winner!
  14. Nov 21, 2022 at 9:28 AM
    #714
    Buster Saunders
    Buster
    Blue Ridge Mtns, Va
    CygnusX191 likes this.
  15. Nov 21, 2022 at 9:32 AM
    #715
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Which damn thread is this?
    How damn tight are your bearing clearances….
  16. Nov 21, 2022 at 9:45 AM
    #716
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Tight enough that you shouldn't be pouring water in them. That's for damn sure lol
  17. Nov 21, 2022 at 10:04 AM
    #717
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I use a atomizing spray bottle filled with water on my carbureted 427sbc that has a 600" hyd roller cam and a 1k cfm carburetor . I do this twice a year and it steam cleans the carbon off of the combustion chamber and pistons
    zoo truck, CygnusX191 and J Williams like this.
  18. Nov 21, 2022 at 10:04 AM
    #718
    dr4g1116
    Not sure why anyone would do it long term. Maybe one time if you have a stuck valve and you're desperate not to pull it apart. Really no point in cleaning carbon unless it's really bad.
  19. Nov 21, 2022 at 10:06 AM
    #719
    dr4g1116
    That's pretty cool. Do you use a borescope to check out the results? Do you see any notable differences in HP (assuming this is a performance application)?
    CygnusX191 and US Marine[QUOTED] like this.
  20. Nov 21, 2022 at 10:19 AM
    #720
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes I can see definite results from just pulling spark plugs and seeing them clean of carbon . Plus you can noticeably see carbon / soot on the ground from the mufflers . I learned this trick from a friend who has a 434sbc nitrous engine . Carbon build up is a very bad scenario for nitrous engine because carbon allows a build up of hot spots .This can lead to engine destroying nitrous backfires
    Yes I've noticed a huge improvement on my engine in performance after spraying watering the carb
    zoo truck, wilcam47 and CygnusX191 like this.
