Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 29, 2022 at 12:18 PM
    #821
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    No, this was outside of Mexico. Mexico only gets to like 50* and theres snow outside here! :D
    CygnusX191 likes this.
  2. Nov 29, 2022 at 12:19 PM
    #822
    Gunshot-6A
    Conner
    Everett, WA
    30w10. Its that special inverse thermodynamics hydrogen the US gubmint uses :rofl:
    CygnusX191[QUOTED] likes this.
  3. Nov 29, 2022 at 12:27 PM
    #823
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Nov 29, 2022 at 12:52 PM
    #824
    saint277
    saint277 Vigilo Confido
    Hydrogen? hell no, its dihydrogen monoxide in a Tacoma's tires or bust.
  5. Nov 29, 2022 at 12:59 PM
    #825
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    If your friend can get compressed hydrogen cheaper than compressed air, maybe he is smarter than the toyota engineers :stirthepot:
  6. Nov 29, 2022 at 1:05 PM
    #826
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    If your friend filled the tires with pure hydrogen, and assuming he drew a complete vacuum on the tire first (since he's smarter than the engineers) you'd be above the UEL/upper explosive limit of 75% hydrogen. So if the truck did indeed detonate, it was likely something else since the hydrogen would just burn. Have you checked if something else was wrong - say, running 10W-30 in a tight tolerance engine?
  7. Nov 29, 2022 at 1:08 PM
    #827
    saint277
    No way the hydrogen would burn if he pulled full vacuum first, oxygen is required for combustion and non would be present in the tire.
  8. Nov 29, 2022 at 1:22 PM
    #828
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    LOL, WTF is up with the sound? And I feel like I need a shower after all that rubbing, squeezing, and patting.
    But to stay on topic . . . wait, what were we talking about?
  9. Nov 29, 2022 at 1:40 PM
    #829
    Buster Saunders
    Buster Saunders Well-Known Member
    Buster
    Blue Ridge Mtns, Va
    2023 Tacoma TRD Pro, Solar Octane, 6MT
    that must be in the Mexican manual. No way that would work below freezing
  10. Nov 29, 2022 at 1:41 PM
    #830
    saint277
    Just drive for a few minutes and the heat buildup in the tires will melt it.
  11. Nov 29, 2022 at 1:56 PM
    #831
    Gunshot-6A
    Conner
    Everett, WA
    Got a whole tank of it, but he chains it to the frame anytime he brings it over cuz he doesn't want anyone to steal it.
  12. Nov 29, 2022 at 3:39 PM
    #832
    KOG89
    KOG89 Well-Known Member
    Castroville C.A
    09 DCSB 4x4 6spd manual
    Ome 2.5 lift front and rear, 886 coils on 9k nitrochargers with hd rear leaf springs. Ko2s on level 8 mk6 wheels. Prinsu roof rack , Bakflip tonneau cover
    OP inspired me to change my oil (jk it was time) I couldn't find any 30w10 oh well
    CygnusX191 and Delta09 like this.
  13. Nov 29, 2022 at 3:43 PM
    #833
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    And this guy just wants to watch the world burn...
    KOG89[QUOTED], andthen and CygnusX191 like this.
  14. Nov 29, 2022 at 5:30 PM
    #834
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Bet it uses the same gutless wide spaced 3 speed from the Wingle. Nothing is sacred in the hundred acre wood
    Just asking for an engine replacement
  15. Nov 29, 2022 at 5:47 PM
    #835
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    he's a master tech FOR toyota? not a good one. maybe he's really the janitor and just tells everyone he's a master tech.
    Look in the lawnmower/snowblower section lol that's what that's used in
    CygnusX191 and KOG89[QUOTED] like this.
  16. Nov 29, 2022 at 7:14 PM
    #836
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    ASMR truck vid? lol
  17. Nov 29, 2022 at 8:31 PM
    #837
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  18. Nov 29, 2022 at 10:40 PM
    #838
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
  19. Nov 29, 2022 at 11:22 PM
    #839
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    This bad boy. Has been running 10w-30 for about 150k. In a perfect motor like a g3. It's much to thick. In a older engine with ring fatigue or seal issues it can get you almost 300k I'll role it next year. Your dad worked on engines that were not the same as today. Can I get his shop name? My g2 has a oil burn he will fix...
    Hug your Dad..
  20. Nov 30, 2022 at 12:11 AM
    #840
    Stocklocker
    17TRDORDCSBAT
    Oh for sure, but if you are paying $8000 for an oil change, regardless of the car’s pedigree, I would argue you are getting an honest-to-goodness boning, no questions asked.
    50Buck[QUOTED] and CygnusX191 like this.
