Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 14, 2022 at 1:05 PM
    #101
    saint277
    saint277 Vigilo Confido
    Unless the tacoma is in mexico? Than the oil flows better in the same temp range?
  2. Nov 14, 2022 at 1:05 PM
    #102
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Don't trust everything you google. Especially when what you find is not application specific. 10w30 didn't blow up the motor lol.
  3. Nov 14, 2022 at 1:06 PM
    #103
    saint277
    No the tolerances magically get tighter when you cross the border to the US, duho_O
    bernuli, CG256, skiploder and 7 others like this.
  4. Nov 14, 2022 at 1:08 PM
    #104
    fourfourone
    :rofl:
    The google mechanics are running wild on this forum.
  5. Nov 14, 2022 at 1:11 PM
    #105
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    The problem is that with the tight tolorances in modern engines the 10w30 will not lubricate the bearings properly and they will spin, blocking the oil journal, wish will intern cause it to seize. DO NOT put 10w30 in for extended periods.
  6. Nov 14, 2022 at 1:11 PM
    #106
    saint277
    FYI, if this is the same page I posted its for a gr2-fks taco. Also I don't think toyota sells the I4 tacoma in mexico, they market the hilux there and if the want the I4 in a pickup you get the hilux instead.
    Hooper89 likes this.
  7. Nov 14, 2022 at 1:12 PM
    #107
    saint277
    So does the Mexico Tacoma have different Specs to allow for thicker oil?
  8. Nov 14, 2022 at 1:12 PM
    #108
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Actually I'm an ASE Master Tech, VW Master Tech, BMW Level 2 Certified tech, and currently a Toyota Expert Level Certified Tech. I have over 20 years experience. And have a little knowledge in the automotive field. And have had more engine classes then 90% of the key board warriors on here. So you are correct. I'm just another "Google mechanic"
    Reggie4x4, SWPA Tacoma, DRAWN and 5 others like this.
  9. Nov 14, 2022 at 1:13 PM
    #109
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Mexico is closer to the equator. Lower latitudes, larger effective diameter of the planet there, more rotational speed helps pull the oil into those tight tolerance bearings. Engineers considered this. That's the real reason oil gets thinner as you go north.
  10. Nov 14, 2022 at 1:14 PM
    #110
    MulletTaco
    Kevin
    Somewhere in AZ
    Couldn’t tell you. What I can tell you is that there’s a reason they require 0w20 and it’s not to get you to spend more money.
    elmontemike likes this.
  11. Nov 14, 2022 at 1:15 PM
    #111
    saint277
    So the engines are the same as the US, same plant same tolerances. So the thicker oil will not damage bearings (provided you stay in the temp range), there is a reason but that's not it.
  12. Nov 14, 2022 at 1:15 PM
    #112
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The problem is the statement of an engine "requiring" 0W-20. Why does it require it here, but not in Mexico? They're the same engine. That is why the Mexico argument is brought up. Same damn engine, the Mexico manual gives the Mexican owners a specified safe range of viscosities to use in specified temperatures, as long as you stick within those temps, you are good no matter where you operate the engine. SO, you can use 0W-20, 5W-20, 5W-30 at any temp, and you can use 10W-30 for 0F+, and you can use 15W-40 for 10F+.
    It really is that simple. Mexico is not as strict on CAFE requirements, nor do they have as many rules, so what is suggested or "allowed" to be used as oil there is more lenient than what they'll put in the owner's manual here.
    There are not "ultra tight clearances", "ultra tight tolerances", or whatever else anyone wants to say to suggest thicker oil won't "fit" in the engine components. At one point, a smart feller on this forum pointed out the main bearing clearances of the 2GR vs the bearing clearances of I believe a 1GR motor from 1991 that had the same bearing clearances (2GR might have actually been larger?) and that older motor used 10W-30 or 5W-30 depending on climate.
    Also, if you look at the Mexican manual and convert the wording, it says that only ILSAC SN is required down there. the ILSAC GF ratings are likely for fuel economy/CAFE here as well, hence why they are not "required" in Mexico either. Now, I do think GF ratings are good to stick to, because at least the latest ones, have additives that are supposed to help with timing chain wear.
    bernuli, ceh527, Taco y mas and 2 others like this.
  13. Nov 14, 2022 at 1:17 PM
    #113
    saint277
    Toyota manual actually doesn't "require" anything, they only "recommend" stuff.
  14. Nov 14, 2022 at 1:18 PM
    #114
    BLtheP
    Plano, TX
    Yep.
  15. Nov 14, 2022 at 1:19 PM
    #115
    fourfourone
    Stop with the tighter tolerance googled BS.
    Take a look at a main bearing clearance spec from a modern Toyota 3.5 and pick any 20 plus year old Toyota engine. They either the same or almost the same. Plenty of these old Yota motors will run on 20w50 no issue and had a recommended oil weight of 5w30 or 10w30.
  16. Nov 14, 2022 at 1:19 PM
    #116
    BLtheP
    Plano, TX
    This shit never ends.
  17. Nov 14, 2022 at 1:20 PM
    #117
    saint277
    20w-50...... so THICCC
    gsubioguy, skiploder and RubyTaco21 like this.
  18. Nov 14, 2022 at 1:22 PM
    #118
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Hot 30 weight is thinner than cold 0 weight.
    skiploder likes this.
  19. Nov 14, 2022 at 1:25 PM
    #119
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
  20. Nov 14, 2022 at 1:27 PM
    #120
    saint277
    That isn't your train, you be riding someone else's train.
    Hercanstein likes this.
