Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 14, 2022 at 1:29 PM
    #121
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
  2. Nov 14, 2022 at 1:29 PM
    #122
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Well this is a fun debate.
    I suspect the specs are loose in Mexico because 0W20 isnt the most commonly found oil there.
    However, I can walk two blocks and find it at four stores within that distance, not including same-day-delivery online orders, so why not use the manual's top recommendation?
    HiBillyMaysHere likes this.
  3. Nov 14, 2022 at 1:31 PM
    #123
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Toyota
  4. Nov 14, 2022 at 1:31 PM
    #124
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I think we can pretty much stop even discussing his oil choice. He has a supercharger he didn't even disclose in the post, who knows what else isn't being told. I'm sure there's way more to the story than "dad threw in thiccc motor oil and the engine grenaded a year later for no reason at all."
    He already said the head gasket failure is what happened, and oil doesn't cause that. And now, mysteriously, he's no longer commenting.
  5. Nov 14, 2022 at 1:32 PM
    #125
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Is it Friday already :rolleyes::eek:
    Delta09 and wilcam47 like this.
  6. Nov 14, 2022 at 1:33 PM
    #126
    clip
    VA
    15 OR
    OP is busy driving to a Mexico dealer to get the warranty work done?
  7. Nov 14, 2022 at 1:34 PM
    #127
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    dont put the drain plug gasket in and drive it...sounds like something wasnt done right...
    Squirt likes this.
  8. Nov 14, 2022 at 1:37 PM
    #128
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Mexico manual calls for peanut oil, but I used canola oil; help
    edit: oops, looking at tortilla chip recipe pdf, not truck manual. Is truck ok?
  9. Nov 14, 2022 at 1:38 PM
    #129
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    No shit, your point?
    Squirt likes this.
  10. Nov 14, 2022 at 1:38 PM
    #130
    HiBillyMaysHere
    HiBillyMaysHere Well-Known Member
    PNW
    2021 TRD Off Road Access Cab
    Olive oil is the superior oil. Fight me.
  11. Nov 14, 2022 at 1:39 PM
    #131
    Bishop84
    Bishop84 Well-Known Member
    Virgin or slutty?
  12. Nov 14, 2022 at 1:39 PM
    #132
    HiBillyMaysHere
    PNW
    Yes.
    gsubioguy, andagi808 and TireFire like this.
  13. Nov 14, 2022 at 1:40 PM
    #133
    Off Topic Guy
    extra virgin; because virgin isn't pure enough
    gsubioguy, RubyTaco21 and MulletTaco like this.
  14. Nov 14, 2022 at 1:40 PM
    #134
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Only if you don't have fresh squeeze baby oil available.
    MulletTaco and Rock Lobster like this.
  15. Nov 14, 2022 at 1:48 PM
    #135
    wilcam47
    Will
    Bourbon state
    /thread
    Squirt and Sterling_vH111 like this.
  16. Nov 14, 2022 at 1:49 PM
    #136
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well damn, guess my Tacoma and Subaru are gonna blow up when I run a 0/5w30 in both of them the next oil changes...
    Squirt and wilcam47 like this.
  17. Nov 14, 2022 at 1:50 PM
    #137
    Off Topic Guy
    They'll be fine, just so long as you cut it with some mineral spirits or paint thinner
    Squirt, wilcam47 and Delta09[QUOTED] like this.
  18. Nov 14, 2022 at 1:51 PM
    #138
    wilcam47
    Will
    Bourbon state
    gsubioguy, asuchemist and Squirt like this.
  19. Nov 14, 2022 at 1:51 PM
    #139
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Meh, I'm going all out and using Methyl Ethyl Ketone (MEK)...
  20. Nov 14, 2022 at 1:53 PM
    #140
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Do you live in Colorado? Please, put down the bong.
    Steves104x4, Squirt and wilcam47 like this.
