Wrong oil in engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbysk123, Nov 14, 2022.
  1. Nov 14, 2022 at 1:53 PM
    #141
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    My 2cents…. The USA has CAFE standards, that is the ONLY reason they say to use 0w-20… to squeeze out another .001 mpg.
    I use the oil that the manual says to use, but 10w-30 falls into the range of acceptable oils. Unless the truck is used in colder climates.
    bernuli and wilcam47 like this.
  2. Nov 14, 2022 at 1:58 PM
    #142
    tclavell
    Troy
    Phoenix, AZ
    G70
    Check the blinker fluid! :thumbsup:
    Squirt, wilcam47 and Delta09 like this.
  3. Nov 14, 2022 at 1:59 PM
    #143
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Those are some sharp engineers to make the necessary calculations to take into consideration, for example, that Tijuana is two blocks closer to the equator than San Diego - never mind that El Paso is closer to the equator than Tijuana.
  4. Nov 14, 2022 at 2:04 PM
    #144
    saint277
    saint277 Vigilo Confido
    Wonder how much PSI the SC was running?
    Squirt and wilcam47[QUOTED] like this.
  5. Nov 14, 2022 at 2:05 PM
    #145
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    He sent it to 11...
    MulletTaco, Squirt and wilcam47 like this.
  6. Nov 14, 2022 at 2:08 PM
    #146
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    This still going?...whatever happened to the burnout thread?
    ToyoTaco25, Squirt and MQQSE like this.
  7. Nov 14, 2022 at 2:09 PM
    #147
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    he sent it till the rods knocked:anonymous:
    MulletTaco, Squirt, Delta09 and 2 others like this.
  8. Nov 14, 2022 at 2:09 PM
    #148
    saint277
  9. Nov 14, 2022 at 2:10 PM
    #149
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Avocado oil, you uncultured boor
  10. Nov 14, 2022 at 2:11 PM
    #150
    saint277
    You need oil from rendered liposuction fat....
    MulletTaco, 5465, Squirt and 3 others like this.
  11. Nov 14, 2022 at 2:11 PM
    #151
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Personally, I prefer coconut oil.
    Junkhead, Delta09, Squirt and 2 others like this.
  12. Nov 14, 2022 at 2:12 PM
    #152
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Hmmm ... 46 ... yep
    Delta09, Squirt and wilcam47 like this.
  13. Nov 14, 2022 at 2:15 PM
    #153
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Geographical facts ... interesting approach. :cool:
    clip, Squirt and wilcam47 like this.
  14. Nov 14, 2022 at 2:15 PM
    #154
    saint277
    I actually just had a relevant thought, I wonder if his SC truck got a tank of non premium gas.
    cryptolime, ret42, ToyoTaco25 and 8 others like this.
  15. Nov 14, 2022 at 2:16 PM
    #155
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
  16. Nov 14, 2022 at 2:19 PM
    #156
    wilcam47
    Will
    Bourbon state
    Sub'd
    Delta09, Squirt and MQQSE like this.
  17. Nov 14, 2022 at 2:20 PM
    #157
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Coconut is entirely too high viscosity for cold weather applications. It doesn't completely fill the channels in my griddle and causes excessive wear between Ahi slices.
  18. Nov 14, 2022 at 2:20 PM
    #158
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Noted :)
  19. Nov 14, 2022 at 2:21 PM
    #159
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Improper lubrication leads to premature connecting rod failure. Common problem with 3rd gens.
  20. Nov 14, 2022 at 2:26 PM
    #160
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    This proves this is what happens when you dont let your engine warm up before driving!
