Wrong plugs in my mini-beast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bad Habits, May 15, 2013.
  1. May 17, 2013 at 9:27 PM
    #41
    elsenordave
    elsenordave HaoleBilt
    Dave Smith
    Blown 2013 NBM DCSB Sport
    AFE CAI TRD Exhaust TRD Supercharger 3" Cornfed Spacer 2" Toytec AAL
    :confused: I do plugs all the time at work and they aren't all one or the other...they are 3 & 3
  2. May 17, 2013 at 9:33 PM
    #42
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Don't bring logic to this octane bashing boom tale. ;)
  3. May 17, 2013 at 9:38 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Oh, I meant that would be the manufacturer.
    Ya, the 4.0, and even my '03 Tundra 4.7, had NGK in one side and Denso in the other.
    I thought the reference was to the 4.0 being copper and the 2.7 being iridium... but they are all either NGK or Denso plugs.
    Not sure I buy the different assembly location though. Pretty sure the plugs go in after the heads go on. They most likely go in after the cams are in and valve covers are on, and the cams and covers can't go on until the engine is assembled to the block.
    What makes more sense is Toyota has contracts with both companies so they aren't stuck if one has a production problem.
    Best way to be able to provide their suppliers with projected usage and avoid confusion on the production line is to simply use a 50/50 mix on the "V" engines.
    If supply becomes an issue, the other supplier can ramp up to compensate, but Toyota will already have stock to use until the accelerated shipments come in.
  4. May 17, 2013 at 9:42 PM
    #44
    elsenordave
    Dave Smith
    Makes sense...I got my 2¢ from a Toyota Hawaii tech guy...either way it's odd but doesn't effect performance :D
  5. May 17, 2013 at 9:44 PM
    #45
    Rich91710
    Rich
    Los Angeles
    08 Base
    Now, copper in one bank and iridium in the other might get interesting around 50k
  6. May 18, 2013 at 3:43 AM
    #46
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The problem is not the plugs the copper ones would run 60K or more in a V6 it's all about the emission warranty. If you want to protect that you'll have to change the plugs at 30K it's a lot cheaper then buying cats. Toyota can deny the warranty if you show up with plugs that have not been changed. Can this happen? Don't know but Toyota thinks it can and that is the reasoning behind the 30K change.
  7. May 18, 2013 at 3:44 AM
    #47
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  8. May 18, 2013 at 7:23 AM
    #48
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I wonder if this is to prove that the plugs have been changed at the 30K mark if any thing goes wrong.
  9. May 18, 2013 at 4:33 PM
    #49
    Rich91710
    Rich
    Los Angeles
    08 Base
    No way to prove it hasn't been done.
    We've had more than a few members here on TW source the same plugs when they changed, assuming that Toyota had a good reason to do so.
  10. May 19, 2013 at 5:15 AM
    #50
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I guess my point is who is going to buy two different brand plugs for each bank?
  11. May 19, 2013 at 10:41 AM
    #51
    Rich91710
    Rich
    Los Angeles
    08 Base
    Some people actually do.
    I don't see the logic in it, but quite a few TW members have indicated that they do so.
    It's no way for Toyota to prove that the work wasn't done.
  12. May 19, 2013 at 1:01 PM
    #52
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    still trying to figure out how iridiums became viable in the 4.0 when I have read NOWHERE in Toyota literature that that is true.
    lots of confusion around here.
    simple way to change spark-plugs correctly: go to dealer, give vin# for truck, ask for spark plugs. if you think they are too expensive, get denso/ngk part# and source otherwise. correct plugs. no worries. no boom
  13. May 19, 2013 at 4:37 PM
    #53
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    No, but all the original spark plugs that come on the engine when they are assemble are marked on the terminal.
  14. May 19, 2013 at 9:21 PM
    #54
    elsenordave
    Dave Smith
    #truestory usually is white
  15. May 19, 2013 at 9:28 PM
    #55
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I read somewhere it had to do with some Japanese law involving fair competition or something like that. Both suppliers plugs are used but you can use either plugs.
