Wrong Tire PSI?
Discussion in 'Wheels & Tires' started by wareagle5693, Nov 5, 2009.
  1. Nov 5, 2009 at 6:25 PM
    wareagle5693
    wareagle5693 [OP] Well-Known Member
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    3" Spacer Lift, with Bilstein 5100s front and rear, BHLM, Satoshi grill, Blacked out tail lights, Midland CB radio, 4' Radio Shack antenna mounted in the bed, Volant CAI, Gibson Exhaust, Magellan GPS, debadged, aries bull bar, pro comp 7089 wheels, Pioneer DEH-P6200BT head unit, eagle eyes halo projector, 8000K DDM tuning HID bulb
    The PSI for my new 285/75/16 Sport King A/T Tires is 65, is that extremely high, and my tire pressure light flashed and came on today and when I got home I checked the tires, and they were all right at 30 PSI, I just got the tires 2 days ago. Why would, if the tire shop properly inflated the tires, they be at 30 PSI?
  2. Nov 5, 2009 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    MAX psi is 65. The correct tire pressure for them on your truck is probably close to 33# or so. Use the chalk method to find the correct psi.
  3. Nov 5, 2009 at 6:30 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I can't understand what you are trying to say, but you should look at the tire pressure chart that is on the inside of the door. It should be a white sticker that will give you that information. But what are you trying to say about the shop?
  4. Nov 5, 2009 at 6:50 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    you sure? and why would my TPMS light be coming on and flashing before it goes solid? I've got a new spare. but I'm not sure why that would effect it because i've got it in the shed right now. it's a fullsize and won't fit under the truck now.
  5. Nov 5, 2009 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The spare has a sensor in it too. It needs to be on the truck, or it will set the light off.
  6. Nov 5, 2009 at 6:57 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I'd take it in (with the spare) and have them checked out...the tire shop might have broke one.
  7. Nov 5, 2009 at 7:03 PM
    TimberT
    TimberT Timberlicious
    Richmond, VA
    2010 SR5 DC
    N-fab Nerfs, Weathertech Liners, Bed Mat, Eibach Springs, AFE Pro Dry filter, Dog slobber
    65 PSI? Spare in the shed? Let go of my leg!
  8. Nov 5, 2009 at 7:04 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    As chris said before, you NEED to put it back on the truck because the spare has a sensor as well. If the computer cannot read that spare because it's out if distance of the computer receiver. So, put the spare back in and hit the reset button and you should be good to go!
  9. Nov 5, 2009 at 7:20 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Well alrighty then. haha And to the guy who doesn't believe me... go on.
  10. Nov 6, 2009 at 3:00 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    The sticker on the door panel is only for same size replacements to the stock set-up, if you go with something different than stock then you should check what the tire manufacturer of that tire says for that size or do the chalk method that Chris posted.
