Wrong Transmission Fluid put in my PreRunner!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by photoman1, Jul 27, 2012.
  1. Jul 27, 2012 at 6:15 PM
    photoman1
    photoman1 [OP] New Member
    Il.
    2005 Tacoma PreRunner
    I have 88,000 miles on my 2005 Tacoma V6 and decided it was time to have some preventative work done including a automatic transmission fluid and filter change. I have not had an ounce of trouble with this great truck until now.
    I took it to a well established local shop (not Toyota) which performed the service. Picked up my truck, drove it for about 40 miles and it then began to shift hard or even bang into a gear now and then. I took it back and explained the problem, they called me back and said they had installed the wrong type of transmission fluid so they drained it and refilled it with the correct Toyota oil. I drove it about 50 miles and it is now worse than the first time. I am of course going to take it back but am wondering if they ruined the transmission and how I should handle this?
    Any input is appreciated.
    Thanks
  2. Jul 27, 2012 at 7:54 PM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    Jiffy Lube did that to my dad. They bought him and installed a new transmission.
    Took some writing and fighting with a regional corporate office, but they didn't push to hard.
  3. Jul 28, 2012 at 6:45 AM
    photoman1
    Il.
    That's what I have been reading online, I hope this doesn't turn out to be a long issue! Thanks for the Information, I greatly appreciate it.
  4. Jul 28, 2012 at 7:07 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Complete flush or a just a drain and fill?
  5. Jul 28, 2012 at 7:55 AM
    photoman1
    Il.
    From what I was told just a drain and fill.
    Thanks,
    Lou
  6. Nov 5, 2012 at 5:05 AM
    mroy5050
    mroy5050 Member
    Clearwater, FL
    05 SR5
    Tires Plus did the same thing to me. I brought it to Toyota to diagnose and fix it. 2005 Tacoma 65,000 miles started running real rough the next day. Cost them $3800 for a brand new transmission plus a rental car for the week. I have 145,000 miles now thinking about taking it to them again.
  7. Nov 5, 2012 at 5:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Before jumping to the conclusion that it needs a new transmission, start with the simple things. Call the place and calmly ask what fluid they put into your transmission. If it's the right stuff, check the fluid level. Incorrect fluid level can make the transmission shift weird.
    If it's the wrong stuff, I'd try having Toyota do a complete flush with the correct fluid. I'd also hand the bill for the work to the place that screwed up the first time by putting the wrong oil in. If you get the correct fluid in the transmission, and it's still acting up, then you might have some damage that won't be easily or cheaply fixed. If that's the case, get ready to do battle with the place that did the oil change in the first place. Because it was only a drain and refill, they likely only drained about 3-4 quarts of fluid and replaced it with the wrong stuff. The transmission holds around 17 quarts I believe.
  8. Nov 5, 2012 at 6:38 AM
    badger
    badger Well-Known Member
    07 SR5
    If they are only doing a drain and fill then all these fluids are getting intermixed. You now have a combination of old fluid, incorrect new fluid, and correct new fluid. Your system needs to be completely flushed and cleaned now before it is refilled. Hard to believe that a few miles on the wrong fluid could ruin the transmission, but :notsure:
