Wrong WDH?
Discussion in 'Towing' started by hambone11, Aug 3, 2019.
  1. Aug 3, 2019 at 5:16 PM
    hambone11
    hambone11 [OP] Active Member
    Jack
    NYS
    13 TRD Off Road
    I have a 2018 Tacoma Sport with tow package. My trailer towing weights vary from 3800 lbs to 4800 lbs. I got sold a 8k-10k WDH at the trailer dealership. They said I would be good if I ever got a bigger truck and trailer. Too heavy a WDH?
  2. Aug 4, 2019 at 8:00 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Yes the WD hitch is to heavy but it can help control sway more than a lighter hitch. I tow the exact same weight with my '18 Tacoma and use a 6K Equalizer. The bars are designed to bend under load and my 6k hitch is designed for trailers weighing between 4 and 6K. When you use 10K spring bars the bars don't flex and it can make for a jarring ride over bumps but can control sway better. Check etrailer.com for the info. I believe they have a video. Also Equalizer has info on the importance of using the right size WD for the weight your pulling.
    I found a link.
    https://www.equalizerhitch.com/blog/05-31-2016/which-equal-i-zer-hitch-model-do-i-need
