WRX exhaust tone
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Feb 24, 2011.
  1. Feb 24, 2011 at 1:13 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you can do it, just keep one side headers stock, then have the otherside wrap around itself a few times, then connect them to y-pipe....bam! Unequal length headers
  2. Feb 24, 2011 at 1:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nope.
    Engine sound is dertermined (aside from muffler, which just changes the tone) by the timing in which that piston is timed on the crankshaft. Take Harley for example. There are tonnes of V twins on the road, but only Harley has its sound.
    Some vehicles are evenly timed, others are staggered in a way to give a certain sound...
  3. Feb 24, 2011 at 1:25 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    then how do you explain the exhaust note completely changing when a subie gets equal length headers, ceteris paribus?
  4. Feb 24, 2011 at 1:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive never heard of anything like that. The exhaust length doesnt affect the timming of the pistons, or fireing sequence. It may change the tone, but the sound pulles will be the same.
  5. Feb 24, 2011 at 1:27 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Chris FTW.
    Another excellent example of this is Yamaha's new firing order and timing in their inline 4 cylinder liter bike. They changed the cylinder firing order, ignition, and valve timing. The displacement didn't change appreciably, nor did the cylinder configuration, or really the exhaust setup. However, it sounds like a totally different motorcycle. The cam's lift and duration has a fairly significant effect on an engine's exhaust note as well.
  6. Feb 24, 2011 at 1:29 PM
    PMK
    PMK [OP] Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    The WRX being flat should the crank journals 180° spaced (paired) or 90° (individual). I'm not sure which since I never owned or worked on a WRX.
    Guessing the 4.0 liter Tacoma is 60°, but again don't know.
    PK
  7. Feb 24, 2011 at 1:31 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    this link:
    http://www.doudna.com/Subaru/
    does cover what Chris said about timing, however, at the end it says if you have independent headers for each cylinder run equally together into the exhaust, it will sound like a regular inline four, hence, how equal length headers will change the sound of the engine
  8. Feb 24, 2011 at 1:31 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    fap fap fap fap fap fap fap fap fap ahhhhh
  9. Feb 24, 2011 at 1:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They can be whatever the manufacture wants them to be set at.
  10. Feb 24, 2011 at 1:35 PM
    PMK
    Florida
    10 DCLB TRD Sport
    I agree, the exhaust timing and lift can make the tone change.
    If they are still running a similar exhaust, which is stated, if it's a four into one then I doubt the tone would change much. Probably the exhaust timinig.
    Haven't looked at the bike, but does it have some type of EXUP or function changing the exhaust effective length.
    Also, being fuel injected, it seems now they are really playing with the ECU ignition portion, the fuel injection program and getting the bikes to work very well with none of the old carb issues.
    PK
  11. Feb 24, 2011 at 1:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They dont necessarilly change the sound, nor make them sound like an I4. Infact, doing so could have adverse performance impact on the engine. In the same link, This guy give some more detail:
  12. Feb 24, 2011 at 1:40 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    http://www.youtube.com/watch?v=HoXkm8i-S4I
  13. Feb 24, 2011 at 1:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Feb 24, 2011 at 1:47 PM
    unentered
    unentered Son of Baconator
    Jacob
    Virginia Beach, VA
    DCLB4x4MGM
    OME 886/Dakar, ARE CX, AMS Filter, WT Mats, 255/85/16s
    What Volkswagen has a horizontally opposed boxer 4?
  15. Feb 24, 2011 at 1:51 PM
    #35
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    I say if you want a WRX sound, get a WRX! Here is my STi next to my wifes Tacoma.
  16. Feb 24, 2011 at 2:27 PM
    #36
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    Now I kinda miss my STI :(
  17. Feb 24, 2011 at 2:29 PM
    #37
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Me too....:(
  18. Feb 24, 2011 at 2:37 PM
    #38
    Blacktacoma23
    2011 Mall Crawler
    Mine:
  19. Feb 24, 2011 at 2:40 PM
    #39
    blackhawke88
    SGV, CA
    07 TRD Offroad
  20. Feb 24, 2011 at 2:40 PM
    #40
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Being the service mgr for a subaru/vw store use the Subaru web site. Subaru.com this will explain everything to everyone about the Subaru and check out the great vids :poking:
