WTB 03-04 A340F 4WD transmission eastern VA
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by hokiee, Jan 30, 2017.
  1. Jan 30, 2017 at 5:13 PM
    hokiee
    hokiee [OP] Well-Known Member
    Gloucester VA
    2003 Red Tacoma TRD
    Transmission needs to be from 03-04 tacoma or 01-02 4 runner. I'm located in eastern VA
  2. Feb 6, 2017 at 7:01 PM
    hokiee
    Gloucester VA
    2003 Red Tacoma TRD
    bump
  3. Feb 8, 2017 at 10:56 AM
    757yotas
    757yotas Well-Known Member
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    What part of va are you in. I know a junk yard that had nothing but tacomas/4runners and mustangs.
  4. Feb 8, 2017 at 11:58 AM
    hokiee
    Gloucester VA
    2003 Red Tacoma TRD
    I'm in Gloucester, work out of new Newport News
  5. Feb 8, 2017 at 12:16 PM
    757yotas
    2007 TRD Sport
    Im in Va Beach, look up Johnsons Mustang and Truck Parts. They had alot of tacomas and 4runners last time i was there. Pretty run down place with weird people but they have the trucks. Here is the address.
    4513 Bainbridge Blvd, Chesapeake VA 23320
    757 545 8370 is there #
  6. Feb 8, 2017 at 12:21 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    NorCal
    04 4x4
    Icon 2.5 Ext. travel coil overs, Camburg UCA's, rear Icon smooth body 0-3" VS 2.0's and a 2" AAL. Custom color matched retrofit HID 4.0 d2s projectors, dual switchback halos w/ RGB Demon eyes. Deck plate mod. Flow master 40 series. 4D optic 22" light bar & 4D optic Pods. 16x8 Method double standards w/ machined lip, wrapped w/ BFG KO2's. Steel grill insert by DB Customz. TG Front & Rear bumpers and sliders. Tundra Brake Upgrade. Complete Interior LED Swap.
    I know this is kinda off topic but is this the transmission that's in the 3.4 automatic 4x4? I want to know the transmission I have. I have an 04 DCSB Tacoma 4x4 V6 automatic.
  7. Feb 8, 2017 at 12:29 PM
    757yotas
    2007 TRD Sport
    What are you asking?
  8. Feb 8, 2017 at 12:30 PM
    hokiee
    Gloucester VA
    2003 Red Tacoma TRD
    Yes. You can check your door sticker but all auto 4x4s will A340F (95-04) with suddle changes from the 3 sub generations in the transmission. But the 03-04s have a "drive by wire" (per research) that is specific to them and 01-02 4runners (you can't mod anything else to work, due to the ECM).....from what I understand the only difference in 4bangers and the V6 trannys are the bell housing and torque convert (actual tranny being the same)
    And thanks! I will definitely check that junk yard out I hadn't heard about it before.
  9. Feb 8, 2017 at 2:00 PM
    Sicyota04
    NorCal
    04 4x4
  10. Feb 8, 2017 at 2:06 PM
    hokiee
    Gloucester VA
    2003 Red Tacoma TRD
    That's for a A340E which is 2wd ONLY. I would go to an auto part store and write down the correct part number then look for it online to make sure you get the right part. 4x4s ARE A340F NOT E
  11. Feb 8, 2017 at 4:02 PM
    Sicyota04
    NorCal
    04 4x4
    What about this one? This WIX Filters - 58030 Automatic Transmission Filter, Pack of 1 https://www.amazon.com/dp/B002VU0SKY/ref=cm_sw_r_cp_api_Nb7Myb559FHEA guy said he used it and it worked on his truck which is a 4x4. So that's why I was wondering.
  12. Feb 8, 2017 at 4:04 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 Taco w/ a V8
    The cab, Bed and frame are stock...
    Check out car-part dot com for junk yards that sell used parts.
