WTB: 05+ TRD Overhead Console
Discussion in 'Buy / Sell / Trade' started by SLOdrive, Dec 12, 2008.
  1. Dec 12, 2008 at 4:31 PM
    SLOdrive
    SLOdrive [OP] SLOdrive
    Mark
    MO
    sr5 4x4 V6
    K&N, Borla
    Wanted: Working overhead consul for a 2005 Tacoma SR5 extended cab. This unit provides a glasses holder, a L&R dome light and a compass and thermometer display.
    Nevermind. Got it working again . . .
  2. Dec 12, 2008 at 4:35 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Did your display stop working?
  3. Dec 12, 2008 at 5:04 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Gave your thread a bit better title so you can get some more attention...
  4. Dec 12, 2008 at 6:14 PM
    SLOdrive
    Mark
    MO
    sr5 4x4 V6
    K&N, Borla
    Hi Nick, It worked when I tested it before re-installing it. But during the trips to the dealer to identify, find, order, buy and return to obtain the clip that I lost, the resistor was lost. My bad for not soldering it properly. I've obtained a substitute from radio shack but that piece is not working (even tough my soldering has improved) or helping the system perform. Somehow, I've been able to stumble through life without an overhead mounted compass and outside thermometer but now, NOW, that I've been spoiled - not to mentioned the ego being trampled, I am on a mission to make this MF work again. Thanks for asking!
  5. Dec 12, 2008 at 7:23 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    PM sent!
  6. Dec 12, 2008 at 9:01 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Dang how did you loose the resistor? even if it came loose it should have stayed in the black box.. unless you were carting it around dis-assembled..? Good luck to ya.
  7. Dec 14, 2008 at 6:28 AM
    SLOdrive
    Mark
    MO
    sr5 4x4 V6
    K&N, Borla
    Last night I took it apart, for about the 37th time, and plugged in just the temp/compass module. I think I told you Radio Shack sold me an adjustable resistor for $1.66. So, as it was plugged in with the ignition on, I was able to adjust the Ohm setting until the display lit up. So, the thing works again. Thanks again for all your help.
  8. Dec 14, 2008 at 3:50 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    Good job :thumbsup:
  9. Dec 14, 2008 at 5:22 PM
    SLOdrive
    Mark
    MO
    sr5 4x4 V6
    K&N, Borla
    Thanks again for your help . . . I would not have taken the assembly apart had you not posted how to do so. Dude: Thnx!
