WTB: 1.5"-2" Wheel spacers
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Sunner, Apr 12, 2012.
  1. Apr 12, 2012 at 11:08 AM
    Sunner
    Sunner [OP] Well-Known Member
    Looking for wheel spacers, at least 1.5". Let me know what you got. . Centric of course. Thanks.
    Edit: looking for 1.5" Hub Centric spacers.
  2. Apr 12, 2012 at 11:17 AM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    lug-centric or hub-centric?
    also, personally I wouldn't go bigger than 1.25 inch wheel spacers, 2 inch would be pretty extreme. what are you trying to achieve with the spacers? 255's on TRD sport wheels and 1.25 inch wheel spacers gave me the perfect stance.
  3. Apr 12, 2012 at 11:17 AM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
  4. Apr 12, 2012 at 11:19 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    no such thing as 2" in hub centric
  5. Apr 12, 2012 at 11:26 AM
    Sunner
    Well I suppose I should have researched more before posting. I am not sure to be honest. These are the wheel's Ill be getting, I'd appreciate if you can let me know if I require hub or lug centric.
    http://www.wheelersoffroad.com/tacomawheels.htm
    Im only going for a wide stance look right now so Im not too worried with going with a 2". Wont be trailing hard in the truck for a while. Ill get 1.25" spacers once I start doing suspension work.
    Thanks for the link buddy but I'd like to get some that are not as used but Ill let you know.
  6. Apr 12, 2012 at 11:30 AM
    anthony250f
    Anthony
    San Diego, CA
    you dont need a hub centric...it just helps the wheel get perfectly centered on the spacer, you will be fine with a lugcentric spacer, but i would get the 1.5" all pro hub centrics. i had 1.25s with a 16x8 rim on my truck....stance was wide
  7. Apr 12, 2012 at 11:33 AM
    Sunner
    Thanks for the info Anthony, if I dont find a used set Ill order a two pair from AP.
  8. Apr 12, 2012 at 11:36 AM
    Sunner
  9. Apr 12, 2012 at 11:36 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    there's no reason not to go hub centric. why get something worse when something better costs the same?
    Also, if you're getting new rims just get the correct backspacing for your tire size and you won't need spacers. less parts = less worry
  10. Apr 12, 2012 at 11:40 AM
    Sunner
    Im saving alot of money with the wheels from wheelersoffroad already. They are dirt cheap but only come with one type of backspacing(4" IRC). I think Id save more money getting those and spacers then shopping around for the right backspacing I need for that wide stance look(hopefully). Thanks for the suggestion though buddy.
  11. Apr 12, 2012 at 11:49 AM
    tacomalex
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    Just double checked the website, they come in 4 and 4.5 BS. and no problem! I enjoy helping people with their tacos :thumbsup:
  12. Apr 12, 2012 at 12:52 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    They are less than six months old. Damn everyone on TW wants you to wash the mud off before you sell chit...:confused:
  13. Apr 12, 2012 at 6:46 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    Cleaned them.
  14. Apr 13, 2012 at 1:00 PM
    DarkDuck
    DarkDuck New Member
    Bay Area
    Hardened '06 Prerunner Sport V6
    Bilstein 5100 2.5" Strut lift, Bilstein 5100 rear shocks with ProComp Add-a-Leaf, Black RockCrawler 8 hole 17x8 wheels wrapped with BFG 3ply S.W. 285x70x17, T-Rex grill set....
    Got these because I got a great deal on BFG 285/70/17 used! Needed them for clearance with stock wheels, but finally got my RockCrawler Black 8 hole wheels, 4.5" with 0 offset...
    Only used on highway and street 3 weeks of use! They worked great but I really wanted new wheels, and this is a cheaper way to help with clearance up front. I was assured, by three tacoma enthusiasts owners, these are the way to go. They were right, great ride, and helped with the clearance before I was able to get the wheels... took a freaking month!:eek:
