WTB 1st gen. truck, what engine is best?
Discussion in '1st Gen. Tacomas (1995-2004)' started by PensacolaDiver, Apr 7, 2011.
  1. Apr 7, 2011 at 8:31 AM
    PensacolaDiver
    PensacolaDiver [OP] New Member
    Pensacola, FL
    Truckless!
    Hello all, I am a new member and I am on the market for a 1st gen. tacoma. I am unfamiliar with the brand as I have only owned domestic trucks up until now. This will not be a daily driver, it will be my offroad/home depot/bugout truck. 4 wheel drive, obviously, and an extended cab or crew cab only, no standard cabs. Oh, and manual transmission only.
    My question is this: I know bigger is usually better, but is the 3.4 V6 the best engine choice or should I consider the 2.4 or 2.7 for any reason?
    In addidtion to that, is there a particular year(s) I should favor in my search?
    Thank you in advance for any and all information, it is much appreciated.
  2. Apr 7, 2011 at 8:38 AM
    Dhawk1313
    Dhawk1313 Well-Known Member
    Drew
    New Jersey
    99 SR5
    Clear Corners, Clear Turn Signals, Pioneer Headunit, Kenwood speakers up front, Alpines in back, Billy 5100's front + rear, Toytec AAL, Eibach/Toytec Coilovers, Toytec Diff drop, Smoked taillights
    I know I've heard alot of people complain about a lack of power coming from the 4 bangers. I have the V6 and I love it. And as for the year, all years of the first gen are awesome. Mines a 99 and I couldn't be happier :D
  3. Apr 7, 2011 at 8:45 AM
    sandman29306
    sandman29306 Well-Known Member
    Andrew
    Chattanooga TN
    01 PreRunner DC
    Icon COs and rear resis, Deaver leafs. ARB locker in rear. ARB front bumper...Pissed at Gadget for abandoning the Rotrex 3.4 supercharger.
    I am 99% sure that all first gen double cabs are packaged as v6 autos only. I've got 214k on mine with no tranny issues...rushes to knock on something wood based. Good luck with your search.
  4. Apr 7, 2011 at 8:46 AM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    never driven a 2.4 or 2.7L... i've got the 3.4L and I'm quite happy with it. I typically average 17.5 mpg (with mostly city driving) and regularly see 20-21 mpg on all freeway trips. there's no replacement for displacement!
  5. Apr 7, 2011 at 8:47 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Okay welcome
    I would go with the 3.4 V6 for an off road truck the extra power will be nice if you put bigger tires on and not need to re-gear. Also if you want a manual trans you won't be getting a DC the Extra cab and single cab were the only ones with a manual trans. I would go with the Extra cab there is really is not much room for people back there but you can toss shit in there without is getting wet or dusty on the trail if you don't have a camper that is and the bed id 6" so you can haul more stuff.
  6. Apr 7, 2011 at 8:50 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Loving the V6 and hello fellow Gulf Coaster!
    :oldglory:
  7. Apr 7, 2011 at 8:55 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Both engines are good. People tend to like the V6 solely for more power... so either engine is the answer. Bottom line is gas mileage. If the gearing is right, won't really affect your offroading. I'm a V6 guy, but only because I'd never own a manual... did my time with those. I used to have a 1985 (I think) Toyota 4x4 sr22 engine (believe that's the number) manual tranny, it did just fine, even with oversized tires. Thing ran forever... our group of friends just kept selling it to each other as our needs changed. Never feared selling it to a friend, even though it had 200K miles or so on it as it just kept running....
  8. Apr 7, 2011 at 10:10 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I've had both on virtually the same truck (96 Xtra cab/4wd/5spd w/2.7L and 01 Xtra cab/4wd/5spd w/3.4L)...both had the same mods, and I like the 3.4 a lot better. the mileage is also the same (17-22 mpg) for each.
  9. Apr 7, 2011 at 11:45 AM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    I don't think the 2.4L is available in 4x4 Tacoma's. If you have a choice between the 2.7L and the 3.4L, go with the 3.4. Its a great motor and gas mileage isn't much different.
    Although, the 2.7L is obviously smaller and simpler, so its easier to work on and may last longer. However, if you put big tires on it then you will be underpowered.
    I guess there's pros and cons to each, just depends on your priorities.
  10. Apr 7, 2011 at 11:46 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    definitely go with the v6. i wish it had some more power but i think i just need to regear
  11. Apr 7, 2011 at 11:52 AM
    PensacolaDiver
    Pensacola, FL
    Truckless!
    Great info by all, thank you very much guys.
    It sounds like what I initially suspected with the 'no replacement for displacement' rule always in effect, so the 3.4 will be the way I go. Good to know that the standard cab and extended cab are the only body styles I can get the V6 mated to a manual, that will certainly help in my search as well.
    Thanks for the welcome aboard, where abouts in FL are you Joe?
    Have a good one fellas, I'll keep the board posted on my search/purchase!
  12. Apr 7, 2011 at 11:54 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    v6! 3.4!
  13. Apr 7, 2011 at 12:53 PM
    thegame
    thegame WUT?
    Brian
    Bay area
    01 Prerunner -> 4wd IFS -> Dana 60 SAS
    You are 100% wrong. Double cabs came with a 2.7 as well. Not sure where you got your info.
  14. Apr 7, 2011 at 3:42 PM
    STLharry
    Harry
    VT
    Yes. But only in 2001 and very few were made because it was not a widely distributed option. No 01-04 DC tacos were manual though.
  15. Apr 7, 2011 at 5:29 PM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    2.7 is pretty nice, I hear great stories on its longevity. We've got the 2.7 with a 5 speed, gets crazy good mpg for a lifted truck, good enough power. We live at 7000 ft, seems to do fine.
