WTB: 2009 tacoma stock radio 6 cd-player MP3
Discussion in 'Buy / Sell / Trade' started by tc2008, Sep 14, 2008.
  1. Sep 14, 2008 at 5:24 PM
    tc2008
    tc2008 [OP] Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    as title say if anyone want to sell their let me know willing to work out a reasonable price for it...
  2. Sep 14, 2008 at 6:13 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    if your trying to put this in a later model i.e. 05-08, i think you need more wiring behind the head unit to make it work. just an f.y.i
  3. Sep 14, 2008 at 6:14 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    you serious?
  4. Sep 14, 2008 at 6:24 PM
    jaxchrisfla
    flooriduh
    lots
    yes, its what i was told when i looked into when the 09s came out.
  5. Sep 14, 2008 at 6:25 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    so that guy just sold his 09 stock radio said you could install in 05+ he lied?
  6. Sep 14, 2008 at 8:26 PM
    weihenstephaner
    weihenstephaner Hooked
    Atlanta, GA
    2009 4x4 TRD OR DC SB Mag Grey
    Slee Slidersteps, 05-08 tails, AFE Pro Dry S, mudflap and TRD sticker delete, Weathertechs
    The plugs are the same for 2009 and pre-2009. I don't know for absolute certain whether it will swap or not, but i think it should. You are obviously going to lose functionality for the mini-plug line-in, since there's not one on the pre-2009 models. But the stereo itself, the speaker connections, etc. should be the same.
    Here's a thread from TN with the back of a pre-2009: http://www.toyotanation.com/forum/showthread.php?t=252634&highlight=changer.
    Here's the back of a 2009.
  7. Sep 14, 2008 at 8:29 PM
    weihenstephaner
    Atlanta, GA
    Also, when I did my swapout I used a harness kit for a 2005-2008 to hook my aftermarket head unit into my truck's harness. It worked without a hitch, so the connectors that matter (power, ground, speaker connections, illumination, etc.) seem to be the same for the 2005-2008 and the 2009.
  8. Sep 14, 2008 at 8:32 PM
    jaxchrisfla
    flooriduh
    lots
    thats good to know someone else has more info, and im not out on a limb here. when the new trucks came out i asked a vendor about the ability to do the swap and at time it was not known for sure if it would work or not.
  9. Sep 15, 2008 at 1:33 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    I was going to get the one just in the sale section (replied on the TN forum), but he said that for sat. radio to work you have to buy a $60 cable to hook up to the stock (on 09s) sat. antenna. So basically you would have to find an antenna that matched the input on the cable. Since I couldn't use the aux input, or the sat radio, I decided against it for now.
  10. Sep 15, 2008 at 1:42 PM
    weihenstephaner
    Atlanta, GA
    That $60 antenna (Part # SFA12M) is what you use to hook up an aftermarket satellite receiver to the factory antennae. It has a generic satellite antennae connection on one end and a Toyota-specific plug on the other.
    To connect the factory receiver to the factory satellite setup, the dealer sells a kit. I think they call it a "fit kit". I never priced it out since I knew I was swapping out the head unit regardless, but I have a feeling it is a good bit more than $60.
    For anyone who's swapping out head units, though, that SFA12M works great to connect an aftermarket satellite receiver to the factory satellite antennae. Damn expensive for just a cable, though.
  11. Sep 15, 2008 at 6:41 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i saw a guy on tn i believe that had one for $100. go get it quick!!
  12. Sep 15, 2008 at 6:53 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    Uhh...I believe it's the same guy as over here that just sold his over here...
  13. Sep 15, 2008 at 7:15 PM
    weihenstephaner
    Atlanta, GA
  14. Sep 21, 2008 at 11:36 PM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    so If i have the 09 cd player I can't just plug and play for the 06 for the FM channel? if I get that $60 cable for the satellite do I have to pay monthly for the satellite?
  15. Sep 22, 2008 at 4:13 AM
    weihenstephaner
    Atlanta, GA
    what? you're confused. FM should be plug and play. satellite is not, even for 09. for 09 you still have to buy the XM receiver and connection kit.
    09 and 05-08 have the same FM antennae. 2009 also has a built-in satellite antenna. 05-08 do not (except JBL, maybe?). that $60 antennae is for 09 models, or 05-08 i guess if you retrofit with the built-in antenna .
    why not go the easy route and get an aftermarket satellite-ready HU and a satellite tuner? so much easier than trying to piece together all the parts needed to have satellite on the stock radio, probably cheaper, and better sound too.
  16. Sep 22, 2008 at 7:46 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    oh in that case then I don't need the Satellite stuff cause I ain't rich to be rolling like that All I want just to play the Mp3 and the ipod that's all, That's why I'm so crazy about the 09 cd changer...
  17. Sep 22, 2008 at 7:51 AM
    weihenstephaner
    Atlanta, GA
    yeah, the MP3 capability is the main difference, to me at least. even with a non-JBL 2009 you have to buy expensive dealer parts to get the satellite radio up and running. really stupid, if you ask me. it was cheaper for me to buy a nice aftermarket HU and XM receiver than it would have been to get the factory XM receiver and installation kit.
    my wife' s 2005 Accord came with the XM up and running with no extra BS to buy, and she didn't even opt for any special stereo package. toyota is definitely nickel and diming the customer on this.
  18. Sep 22, 2008 at 7:55 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    Honda they come with everything if you ask me. Hell they even come with a car alarm with window roll down feature for FREE!!! while toyota they charge you a grip to those stupid factory alarm that does nothing but just beep and lock that's it!
  19. Sep 22, 2008 at 7:59 AM
    weihenstephaner
    Atlanta, GA
    lol. i'm old and uncool. grip? i've seen that word used several times, but what does grip mean in the context of cost?
  20. Sep 22, 2008 at 8:01 AM
    tc2008
    Garden Grove, CA
    06 Speedway Blue
    uhh...ok I guess it replace "fortune" :rolleyes::boink:
