WTB: 4.10 Tacoma non e-locker gears with or w/o 3rd member
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Tacoma30, Mar 3, 2012.
  1. Mar 3, 2012 at 9:15 PM
    Tacoma30
    Tacoma30 [OP] New Member
    Chad
    Hawaii
    2011 dbl cab sr5
    3" Djm drop, Volant intake/scoop
    Found some, thanx chopshop! Can't wait to get em in!
  2. Mar 4, 2012 at 1:52 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Total Chaos Mid Travel, Sway away coilovers,31x10.50x15 goodyear wrangler authority's
    I just bought a set of 4:10 gears from a guy with a 2011 4wd 4cyl open diff truck manual tranny . I'm not sure if all Tacoma 5lugs have different bolt patterns for the ring or just my year but I have a 2006 5 lug and was told by the dealer there are three possibilities. 8 hole 10 hole and 12 hole, I had the 12 hole pattern. This was determined by the last 8 #'s of my vin. The 4cyl 4wd ring shares this 12 bolt pattern. Call your dealer and see what you have, also east coast gear supply sells used 4:10 gears from a t100 that will Bolt up. Those can be had for about 140 ring and pinion
  3. Mar 4, 2012 at 1:54 AM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    Your auto right? What rims and tire size are you going with? You might need a different ratio. Use the tire size calculator
  4. Mar 4, 2012 at 9:01 AM
    Tacoma30
    Chad
    Hawaii
    2011 dbl cab sr5
    Yes mine is auto, I am comfortable with taking a chance and going with 4.10,
    My tires only are about 26.75" tall but with the wider/heavier setup, I really could feel the lag...
    -- thanks for the heads up about the differrent gears , I'll check on that...
  5. Mar 4, 2012 at 12:43 PM
    5LUGTACO
    5LUGTACO Gear Head
    David
    California
    06 TACOMA 5 LUG
    post up some pics of your truck!
  6. Mar 5, 2012 at 4:54 PM
    Tacoma30
    Chad
    Hawaii
    2011 dbl cab sr5
    I gotta figure out what's easiest way to post a pic and I'll get one on here...
