WTB Drop in bedliner screws
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by pickuptruckguy, Oct 29, 2011.
  1. Oct 29, 2011 at 6:38 PM
    pickuptruckguy
    pickuptruckguy [OP] Well-Known Member
    SoCal
    04 Doublecab 4x4
    Need the attaching hardware for a drop in bedliner for a doublecab. Any help appreciated.
  2. Oct 29, 2011 at 7:36 PM
    dark tangent
    dark tangent Well-Known Member
    Madison, WI
    Rigid Dually D2 Amber Driving LEDs mounted on CBI Offroad ditch light brackets.
    I'd try the hardware store...
  3. Oct 30, 2011 at 9:41 AM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    when i took my liner out to clean under it my screws broke. What I did was buy a bolt long enough to go from under the rail thru the liner. Put the bolt thru the existing hole and tighten it on with a nut/lock washer. then put liner in and the end of the bolt should fit into the liner holes and you just put a washer and nut on that to hold liner on. I made it so the bolt still sticks out a little incase I wanted to put a rail or something on it I still have room for that and another nut.
  4. Oct 30, 2011 at 3:14 PM
    pickuptruckguy
    SoCal
    04 Doublecab 4x4
    I just need a couple of the flanges. I can get bolts/screws from hd or dixieline.
  5. Oct 30, 2011 at 3:14 PM
    pickuptruckguy
    SoCal
    04 Doublecab 4x4
    got a pic?
  6. Oct 30, 2011 at 3:47 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    this is what i use [​IMG]
  7. Oct 31, 2011 at 10:47 PM
    Tenzing
    Tenzing Active Member
    The Northeast
    95 Manual Xtracab 4x4 Taco
    Awesome Skull Cigarette Lighter
    I think I still have my set from when I took out the liner. PM me what you think they are worth and I'll check when I go home this week
  8. Oct 31, 2011 at 10:54 PM
    spidy3
    Dom
    Upstate NY
    10 DC TRD Off Road
    this is only pic i have...
    basically you put the bolt in so the threaded end points towards the middle of the bed. tighten a nut on it so the bolt stays there. drop the liner while having the threads go thru the liner then put a washer and nut on (would be the second nut on the bolt). So since you put the first nut on behind the liner the bolt doesnt move and theres no need to hold it when putting the second nut on to secure the liner.
    so it goes.... bolt head/inside of bed rail/nut/liner/washer/nut.
    If you need me to i can try and get a better pic. I'll pull out the liner near the tailgate and show you how the bolt and first nut are on it, but I believe its pretty straight forward.
  9. Nov 9, 2011 at 8:57 AM
    spidy3
    Dom
    Upstate NY
    10 DC TRD Off Road
    get it figured out???
  10. Nov 10, 2011 at 7:13 AM
    pickuptruckguy
    SoCal
    04 Doublecab 4x4
    no not yet, got put on the back burner, but I see what you did and I like it!
