WTB(FOUND IT ) DOOR LOCK ACTUATOR FP
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by taco03Trd, Feb 14, 2023.
  1. Feb 14, 2023 at 7:26 AM
    taco03Trd
    taco03Trd [OP] 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Looking for a front passenger door lock actuator 03 taco DC .
    As anyone fix there’s with out replacing the hole thing?
    Let me know
    Tia
  2. Feb 15, 2023 at 11:00 AM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    What’s the issue? Is it partly working or not at all? What have you tried? Best idea i have is to make sure your electric connections are clean using de-oxit and make sure the ground is good. Then make sure the mechanism is lubricated appropriately, and that the rods haven’t bent or moved over time.
    taco03Trd[OP] likes this.
  3. Feb 15, 2023 at 11:08 AM
    taco03Trd
    Carlos
    Riverside ca
    It make noise went unlocked still works just making a squeaky (cherpy noise ) I haven’t try anything yet . I saw a few videos on this issue an they change the actuador . I was just getting ready to find the part .
    Thanks for your reply
    Rastopher likes this.
  4. Feb 15, 2023 at 11:10 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I changed mine in my 2008. I had a few left over that I think I tossed when I moved houses. they were pretty easy to find online. It isn't a hard fix but a little tricky with the gears and mechanism. not sure if the Gen 1 is different than gen 2.
  5. Feb 15, 2023 at 11:11 AM
    Rastopher
    Ras
    Sacramento, Ca
    Sounds like you could probably solve the issue by tightening up the bolts or with a cleaning and a little dab of grease. Give it a shot! If it isn’t completely broken I’d try to avoid “fixing” it, especially with aftermarket parts.
  6. Feb 15, 2023 at 11:13 AM
    taco03Trd
    Carlos
    Riverside ca
    Yea I’ll try that it out tia
  7. Feb 15, 2023 at 11:14 AM
    taco03Trd
    Carlos
    Riverside ca
    I’m sure they are different parts .
  8. Feb 19, 2023 at 12:27 PM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    I have both front door actuators. $25 for passenger side plus shipping worked fine when i parted the truck. Send me a pm with your zip and I’ll get you a quote.
  9. Feb 19, 2023 at 12:56 PM
    taco03Trd
    Carlos
    Riverside ca
    92503 let me know I’ll be interested for sure
  10. Feb 19, 2023 at 1:37 PM
    Duke_962
    Nwnj
  11. Feb 19, 2023 at 2:18 PM
    taco03Trd
    Carlos
    Riverside ca
    Correct
  12. Mar 5, 2023 at 5:54 PM
    woodardd
    woodardd Well-Known Member
    Seth
    97 first gen
    If you have the driver side and aren’t letting it go I’d take it.
