WTB: Front differential mounting cushions
Discussion in 'Buy / Sell / Trade - Other' started by MMyota, Sep 6, 2011.
  1. Sep 6, 2011 at 5:15 PM
    MMyota
    MMyota [OP] Well-Known Member
    Brandon
    Salem, AL
    01 Prerunner TRD 4x4
    TRD cat back, TRD headers, Airaid CAI, poweraid throttle body spacer, Saw 2.0s, toytec AAL, RG 1" body lift, 4x4/5-speed swap, aussie locker front
    Im looking for the brackets to mount a front tacoma diff to the frame. Should be 95-04 tacomas and 4runners.
  2. Nov 2, 2014 at 9:21 AM
    srsupertrap
    srsupertrap Well-Known Member
    Colorado Springs, CO
    2001 Tacoma SR5 V-6 TRD 4 X 4
    Bilstein 5100s, Borla 14945 S/S Exhaust, Fram Air Hog Filter, Diff Breather Mod & NGK Wires
    I was able to purchase the RH Bracket directly from Toyota which they call Front Mounting Cushion. The RH side was only available when I placed my order in October 2014. I am looking for the LH Front Mounting Cushion .. . . I tried Rock Auto but they don't seem to list it.
    Any sources for this "Bracket would be welcome
    TIA
  3. Nov 2, 2014 at 9:42 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    When I'm done it will have a custom fabbed winch bumper and hopefully a Softtopper.
    Do you want the whole arm or just the bushings? I have them on my '98 parts truck.
  4. Nov 2, 2014 at 11:17 AM
    srsupertrap
    I am looking for whole arm because my bushings are worn & sloppy. My Taco has 156K. As you know the arm contains a pressed in bushing which is not meant to be replaced. Does someone make a replacement bushing for the whole arm?
  5. Aug 12, 2016 at 12:35 PM
    matt 157
    matt 157 Well-Known Member
    California
    2003 Black Xtra Cab 4WD SR5 TRD
    Pioneer DEH 8400 head unit/deck, Crunch 1100 watt amp, 12" Kenwood subwoofer, Kicker mids & tweeters, AllPro front tube bumper, Smittybuilt tow hooks, (welded pipe for muffle) straight-pipe, 4 orange "Raptor" lights in grill, Duratrac tires, American Eagle rims, ProComp 2" front leveling kit, Plasi-Dipped black on chrome trim, PIAA fog lights w/ in-cab switch, Unidin CB/Firestik II/8 ohm PA speaker, TRD leather 5-speed shifter knob
    Sorry to resurrect this thread but did you ever find out if there was a way? I believe mine are so fucking shot that the arm is making a rough clicking noise and I would like to replace mine, but avoid buying the whole arm at the same time..
  6. Aug 13, 2016 at 7:20 PM
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 Tacoma
    Driven Safely
  7. Aug 14, 2016 at 6:13 AM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    All my IFS parts sold a while back.
  8. Aug 14, 2016 at 10:06 AM
    Milota95
    Qrampage
    B.F.E
    97 Tacoma
    Driven Safely
    No problem you're the only one I could think might have it
  9. Aug 14, 2016 at 10:45 AM
    matt 157
    California
    Looks like I need to roll the dice at the stealership
  10. Aug 14, 2016 at 11:18 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    matt 157 likes this.
  11. Aug 14, 2016 at 3:34 PM
    1999RegCab
    Cacti Land, AZ
    3-link SAS
    It's all good. I appreciate the referral :D
  12. Aug 14, 2016 at 9:02 PM
    License2Ill
    License2Ill I don't think she likes the special sauce, Rick
    Ian
    AZ Über Alles
    2004 SC'd 5VZ DC 5spd 4x4 TRD
    SC'd Double cab 5 spd
