WTB gas door lock
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by sonjason, Jan 31, 2014.
  1. Jan 31, 2014 at 11:56 AM
    sonjason
    sonjason [OP] Pink Taco Lover
    Western NC
    85 Turbo Diesel 4x4 Yota
    Anybody got a lock for the fuel door that works and has a key? How much shipped to 28786?
  2. Feb 1, 2014 at 7:54 PM
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    I been looking for one for over a year dealership wants 80 for lock
  3. Feb 1, 2014 at 8:11 PM
    MOTACO
    MOTACO Active Member
    SW Missouri
    Tacoma 4x4
    Proper air pressure in tires, clean windows, coins under seats.
    If you only need the small plastic arm that goes on the end of the lock cylinder (which latches the fuel door closed), then check out this link:
    http://www.thingiverse.com/thing:27563
    I downloaded the files and had a local company print them on their 3D printer. I haven't assembled it yet. I probably won't get to it for another few weeks but once I do, I'll post up a review here.
    If you decide to go the same route and can't find a local 3D printer, just let me know and I'll put you in contact with the company that I used. They can print the part and mail it to you for a very reasonable fee (I paid $10).
  4. Feb 1, 2014 at 9:10 PM
    trailbikerider
    trailbikerider Well-Known Member
    Phoenix, AZ
    2002 4Runner Limited
    ^I would definitely be interested in that.
  5. Feb 2, 2014 at 5:21 AM
    garyp
    garyp Well-Known Member
    Gary
    Germantown TN
    97 Taco
    I need this part also.
  6. Feb 2, 2014 at 5:52 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    "If you decide to go the same route and can't find a local 3D printer, just let me know and I'll put you in contact with the company that I used. They can print the part and mail it to you for a very reasonable fee (I paid $10)."
    Why not post up the link, I am nowhere near a facility with a 3D printer, I have been looking for this part for three years, refuse to pay the dealer $80....
    Update: Downloaded files (I think you only need the big one), but there is a lock on the files when accessing the file, so useless even if I found a shop with a 3D printer....does the shop that built yours still have the file on hand that you used?
  7. Feb 2, 2014 at 6:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    When I'm done it will have a custom fabbed winch bumper and hopefully a Softtopper.
    I got one.
    I'm parting out a 1998.
    $35 for the whole door, lock and key.
  8. Feb 2, 2014 at 12:59 PM
    koditten
    Kirk
    Central Michigan
    Here are pics. I can't seem to post them in a pm.yqaryzer_fbc82e1d39b5fa2e7b18e50a8f5b8b1a51c3bc9f.jpga3ugeran_0bfb40607708a30165e704c4680e9c94c1fdc52f.jpgduvy3uqa_11acdcd0f79767c3a5b478b133f91d60252dd4a3.jpg
  9. Feb 3, 2014 at 5:53 AM
    garyp
    Gary
    Germantown TN
    97 Taco
    Don't need the door, just lock.
  10. Feb 3, 2014 at 8:24 AM
    MOTACO
    SW Missouri
    Tacoma 4x4
    My part was 3D printed by Ely Scot Enterprises, LLC. I worked with Justin, the Director of Product Development. He was very professional and helpful throughout the process. If you're interested in using his company, I'd suggest that you email him. Here's a link to their website:
    http://elyscot.com/
    They may still have the 3D part files, I don't know. I had no problem downloading the files from:
    You will need both the small and the large parts 3D printed. Though I haven't installed it yet, from what I understand, the small part (essentially a plastic disc with a slot in the middle) slides onto the lock first. It is then rotated 1/2 turn. Then the large part slides on the lock and the small disc is glued or plastic welded to the large part, thereby securing the large part onto the lock.
    From my brief handling of the 3D printed parts and the lock cylinder, I think there may be an issue with how the spring attaches to the new 3D printed part. The original plastic part had a plastic skirt that extend in towards the lock body, to which the spring attached. The new 3D printed part lacks that skirt. When I get around to installing the part, and attaching that spring, I'll post how I resolved the spring issue.
    This doesn't appear to be a simple or perfect fix. But it may be the most economically viable fix, apart from purchasing a whole new lock.
  11. Feb 3, 2014 at 11:58 AM
    kurts74
    kurts74 Active Member
    Flagstaff, Arizona
    1gen Tacoma
    Deavers J59 Camburg UCAs Icons front and rear Allpro 1.5" shackles Centric powerslot rotors Centric pads Diff breather extension Hard candy shell
    That is excellent info about the 3D printer and making that arm. I could have used that last year, I looked for a long time but could not find that piece. So if it helps anyone what I ended up using was a small metal rod (hallow). Cut a notch in one end, slipped it over the metal T (part of the lock) and clamped the other end with a squeeze from some pliers. It ended up looking good, its functional and cost <$1.
  12. Feb 3, 2014 at 12:37 PM
    tacotundra
    tacotundra Well-Known Member
    i keep looking at buying a 3d printer.. i see the prices are coming down on them...
    I replaced my lock last year i bought in from a online dealer paid like 50 bucks for it...
  13. Feb 3, 2014 at 3:55 PM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    Hello, Quick question...Does the 98 gas door fit out 1st Gen trucks? If so i would like to purchase it. 03 is my year
    I have always wanted the locking gas door as i have had on my older year Tacomas.
    Thank you for your time
    >G
  14. Feb 3, 2014 at 4:14 PM
    koditten
    Kirk
    Central Michigan
    I'll have to check. I have an 04 with no lock. The doors look the same, but there is no latch for the lock to grab. It may be as simple as changing the cap bezal to make it work. Be advised that I already sold the lock, but still have door. Will check when it get light on Tuesday.
  15. Feb 4, 2014 at 9:31 AM
    sonjason
    Western NC
    I don't need the door. Will you take $20 for just the lock and key? By the way I started this thread lol.
  16. Feb 5, 2014 at 12:18 AM
    koditten
    Kirk
    Central Michigan
    I have had lots of interest on my locking door.
    Just to be fair, I would rather sell the whole assembly, the door isn't very useful without the key, so I would rather keep everything together.
    People have asked if there is a difference. Here are some pics that show what us what.4ugubuhe_1704d0b7d0787afe0ac7e32b0c9eb7ce8bdada22.jpge5any9aj_7c594141e2bdeb8d427e5cf7f23b07ce447768a1.jpgu9ymasa2_312d8564fe60efa1b1f69211eaaea5f14417218e.jpg
  17. Feb 5, 2014 at 12:29 PM
    sonjason
    Western NC
  18. May 25, 2014 at 1:59 PM
    MOTACO
    SW Missouri
    Tacoma 4x4
