WTB, HEADERS EXHAUST INTAKE
Discussion in 'Performance and Tuning' started by emilminasian, Apr 14, 2013.
  1. Apr 14, 2013 at 8:22 PM
    emilminasian
    emilminasian [OP] Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    I need some suggestions for headers exhaust and cai or if someone is selling there's please hmu!!;)
  2. Apr 14, 2013 at 11:39 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    what exactly do u need help with?
    intakes................. u have the AFE stage 2 Si (no cooler than stock, but it does away with the stock accordian crap)
    U also have URD but it wont do well with deep water crossings.
    and the 1st run TRD intakes (made by AFE)
    Volant U can get with or without the skewp thingy and may or may not have check engine lights
    headers...............
    U have JBA
    u also have doug thorley short tubes or long tubes.....shorties reuse ur cats (u need to remove and have them welded to the shortie headers)
    exhaust..........stay away from flowmaster
    otherwise, the exhaust market is waaaaay too vast to sum up in 1 post/thread.
    u want loud, performance, rasp, dual, single, cat back, just a muffler?
    Id def suggest NOT going above 2.5" if ur not gunna go with forced induction.
    check urdusa.com for goodies
  3. Apr 14, 2013 at 11:43 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  4. Apr 15, 2013 at 8:12 AM
    emilminasian
    Emil Minasian
    Glendale, CA
    Thanks for the help! And I'm just trying to see what people recommend for permanent parts as far as the brands , not really looking to make it louder just to perform better lol
  5. Apr 16, 2013 at 6:04 PM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    What I would do is leave stock manifolds if its not forced inducted. just port the manifold to match the gasket. I'd put high flow cats any flow through design Is fine. As far as mufflee that's up to you . After you do what ever you choose you need to have it tuned. The reason I say do that to stock manifold is because most Toyota manifolds flow the same or more than aftermarket just speaking feom experience.
  6. Apr 16, 2013 at 8:13 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    :popcorn:
    do tell, I had no idea
  7. Apr 17, 2013 at 3:41 AM
    colby8100
    Colby
    South carolin
    I havnt messed with newer stuff but a lot of Toyota heads are designed by yamaha and exaught. I am assuming the truck is a v6 lets say (this is what problem I ran into) toyota designed it to be a high velocity and backpressure set up. Since most vvt cams are set up with 0 over lap for emissions the back pressure helps the valves close so they put small ports to keep back pressure and make the velocity high to get the gasses out just as fast as a larger exaught but you keep your low and mid range torque. So through headers 2.5in dual high flow cat and high flow muffler, 2.5 dual is an 800hp rated exaught so back pressure would be decreased so loss of torque loss of gas mileage for what 20hp at 6000rpm. The reason I say port the manifold is because a lot of castings have a lip that causes the gasses to tumble instead of flow. So doing it you reduce turbulence in manifold which increases flow but keeps necessary back pressure for head creating more hp and keeping low end torque. So without cams or boost the stock manifold will flow the best.
