WTB: leaf springs
Discussion in 'Buy / Sell / Trade' started by rollacoasta15, Dec 8, 2010.
  1. Dec 8, 2010 at 1:00 PM
    rollacoasta15
    rollacoasta15 [OP] Well-Known Member
    Serge
    NOR CAL
    Stud
    lift and rims
    Want to buy leafs for 05-11 for 4 door shortbed.
    Preferrably the ones for heavy load, I will take regulars also. Thanks guys.
  2. Dec 8, 2010 at 2:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have some for a 1st Gen, not sure if they fit a 2nd Gen. They are 3 leaf with an overload leaf. Rated at 700 lb over. Give about 3" of Lift. Basically brand new. Only on my truck for about 3 weeks.
    PM me if interested.
  3. Dec 8, 2010 at 3:21 PM
    rollacoasta15
    Serge
    NOR CAL
    Stud
    lift and rims
    Where are you located? I will check if first gen fit on second.
  4. Dec 8, 2010 at 3:45 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Seattle metro
  5. Dec 8, 2010 at 4:26 PM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black, it has a Volat Cold air Intake, 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a gold rings! brush bar with 4 LightForce 170 strikers, Custom rear Bumper, Straight Pipe. HID 6000k Hi/Low, and HID 6000k fog lights, Tinted rear tail lights! Flat Black Interior! 2 12" subs with custom box made by me and a 1300 watt amp!
    How much you want to spend
  6. Dec 8, 2010 at 6:53 PM
    rollacoasta15
    Serge
    NOR CAL
    Stud
    lift and rims
    Not a whole lot.how much you asking?
  7. Dec 8, 2010 at 7:20 PM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    I have the tow package and a 2in aal on them so about $200
  8. Dec 8, 2010 at 8:48 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    You probably already know this, but adding/changing springs will not change the load capacity of your truck. Your brakes, engine, transmission, cooling, etc. dictate how much you can haul. That being said, if your truck is out of warranty and you cannot get the rear spring TSB, an add a leaf (AAL) is a great option. The Toytec 1.5" combined with a set of Bilsteins up front or an aftermarket set of coil-overs will make a nice difference, but still won't add to your load capacity.:)
  9. Dec 8, 2010 at 9:15 PM
    rollacoasta15
    Serge
    NOR CAL
    Stud
    lift and rims
    Thanx guys, I apreciate your advice. I don't want to do any hardcore towing, just load her up occasionally with firewood or lumber or toyys.so tsb would be awesome but regulars are good too.and what's this aal I hear bout?
    Can someone fill me in on it?
  10. Dec 8, 2010 at 10:03 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    it will add some load carrying comfort... with more than 500lbs. my truck bounces off the bumpstops over speed bumps...
    IMO toyota way over estimated the load the truck can carry in the back... if i put 70% of the load capacity im bottomed out...so if adding a beefier leaf makes it so you dont bottom out so bad, in effect your increasing load capacity...;)
  11. Dec 8, 2010 at 11:01 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    an AAL is an Add A Leaf...its a leaf spring thats added to the stock rear for extra height. Common leaf lifts are 1 1/2 and 2".
